electric fuel pump https://ausmini.com/forums/viewtopic.php?f=5&t=9968 |
Page 1 of 2 |
Author: | benjamin [ Wed Aug 10, 2005 6:40 pm ] |
Post subject: | electric fuel pump |
ok im absolutly sick of mechanical pumps dying and my knuckles hurt from changing then so im going to get an electric one i have a couple of questions: what pressure do i need as i have a hif44 Turbo carb ??? if i mount it on the rear subframe where do i connect the + wire to ??? i found this one on ebay looks pretty good is 9psi too much pressure ?? http://cgi.ebay.com.au/ws/eBayISAPI.dll ... Pr4_PcY_BI any help would be great thankyou |
Author: | drmini in aust [ Wed Aug 10, 2005 8:40 pm ] |
9psi is way too much. :cry: I use a Purolator square one (5/16" lines) on Barney (twin HS4s) and a TRW square one (1/4" lines) on Ha-Ha (45 Dellorto). Both these pumps are the same as a Facet one. I mount them on a Mini square centre exhaust mount to shut 'em up... ![]() Most spares places carry these pumps, or can get. Both pumps are running without a regulator, no problems or flooding. You will need to run a 12V+ wire from ignition switch, or bottom fuse. |
Author: | benjamin [ Wed Aug 10, 2005 8:45 pm ] |
what is the most pressure i can have without needing a regulator? |
Author: | drmini in aust [ Wed Aug 10, 2005 8:46 pm ] |
Probably 4psi. |
Author: | benjamin [ Wed Aug 10, 2005 8:50 pm ] |
http://cgi.ebay.com.au/Mini-FACET-High- ... dZViewItem is that one what i need and is it a good price? |
Author: | Wolfman [ Wed Aug 10, 2005 9:13 pm ] |
benjamin wrote: http://cgi.ebay.com.au/Mini-FACET-High-Volume-Electric-Fuel-Pump-NEW_W0QQitemZ4562927589QQcategoryZ32072QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
is that one what i need and is it a good price? That's it, slightly below rrp but not by much, probably dearer when shipping is added. |
Author: | benjamin [ Wed Aug 10, 2005 9:17 pm ] |
ok my last question: id say the black wire would just be earthed on the chassis but where does the + red one go so that the pump only works when the ignition is on (clubbie by the way) |
Author: | drmini in aust [ Wed Aug 10, 2005 9:23 pm ] |
is that one what i need and is it a good price? Yes and yes. Mine (same) cost over $100.... ![]() |
Author: | drmini in aust [ Wed Aug 10, 2005 9:24 pm ] |
benjamin wrote: ok my last question:
id say the black wire would just be earthed on the chassis but where does the + red one go so that the pump only works when the ignition is on (clubbie by the way) Read my post a couple above... ![]() |
Author: | benjamin [ Wed Aug 10, 2005 9:29 pm ] |
drmini in aust wrote: benjamin wrote: ok my last question: id say the black wire would just be earthed on the chassis but where does the + red one go so that the pump only works when the ignition is on (clubbie by the way) Read my post a couple above... ![]() ![]() |
Author: | kazjim [ Wed Aug 10, 2005 9:30 pm ] |
If you are going to Turbo it, you'll need pressure..... I run a Holley Blue pump on mine, it can go to about 19PSI (With out mods - mine can go to about 24Psi ![]() Need a rising rate Reg though.. luckily the Blue comes with a reg that can be modded to suit..... drop me an email if you need the details.... They are Noisy, nasty and Loud... but by god, I've never had a fuel-related hassle yet ! remember, you'll ALWAYS need at least 3Psi ABOVE Boost pressure.....so if you run 14PSI Boost, you'll need 17PSI Fuel Pressure... J |
Author: | PTR_1275 [ Sun Aug 14, 2005 12:34 am ] |
some good advice there. will remember to look back through it when i replace my fuel pump. any one know what the life expectancy of a mech. fuel pump is??? |
Author: | benjamin [ Wed Aug 17, 2005 6:29 pm ] |
well i put that mechanical pump on a year and a half ago ![]() anyway new facet 4psi pump is on and wired to ignition with a 10 amp fuse so im all set i still have my problem of the fuel filter not filling up? its still only 1/8th full????? so i might bin that fuelstar fuel saver thing and see if that helps any other ideas?> |
Author: | awdmoke [ Wed Aug 17, 2005 6:46 pm ] |
PTR_1275 wrote: any one know what the life expectancy of a mech. fuel pump is???
About 10:30pm the next time you go out without tools in the boot & it's raining ![]() |
Author: | Morris 1100 [ Wed Aug 17, 2005 6:50 pm ] |
benjamin wrote: i still have my problem of the fuel filter not filling up? its still only 1/8th full?????
Some filters look like they are empty when they are full. (ryco) What carby are you running? Do you realy need a fuel filter? |
