Good on ya James,,,you`re bloody close
the "Average" stroker donk is made up of a STD/STD large journal crank that has been ground offset to STD Cooper "S" size ( 1.625" from memory),,,
what we do tho, is grind em down offset to about 2 to 3 thou above that size ,,,& then balance the crank,,, & then harden the crank,,, & then grind it all true to bottom clearance size (leaves heaps of room for lots of oil & makes for a very stronk crank indeeed & that way it also makes sure that the crank is all nice & straight after all that work)
we then find a set of Cooper "S" rods, make sure they`re straight for starters,,, fit ARP rod bolts,,,& then re-size them to make them all nice & round & to size in the bearing hole
easy to understand so far???
Then we offset bore the block to 73mm (& prefferably a thick flange "1100S" type or late 1275 moke or 1275LS thinck flange,,,basically any of the thick flanged "Non-side plate" blocks,,,altho there really is nothing wrong with the side plate "S" style blocks at all for road use expecially, use it if you have it, no problemo.
The 74.7mm (Triumph 2500 pistons) one that i used for my 1510cc engines has shown absolutely no drama for 8 years of my abuse until recently it has developed a problem with the centre main bearing recieving a heap of crud from the very old worn out old very 2nd hand & abused gearbox that i simply left in there way to long (naughty me really, not a fault of the engine at all, just my stupid lazyness)
The crank in that engine was infact, as James suggested , an .080 thou undersize thing that really should have gone bang years ago, but has just taken everything that i gave it for those 8 abusive years
& i cannot for the life of me find anymore .080" undersize big end bearings anymore,,,& trust me, i`ve hunted hi & lo world wide,,,if there is anyone out there with another new set, please ring me or e-mail me as i only have one more spare set
& i`d dearly love to have another set for my other 1510cc donk
But,,i really wouldn`t suggest going this big, as said, there`s big problems finding the B/E bearings ,,,main problem #1,,,,& it`s a particularly suspect build for longetivity,,,yeah, i got years out of mine,,, & probably would have got lots more years out of it if i wasn`t so lazy & changed out the gearbox earlier,,,(i will simply grind the mains & build it back up again anyway, there`s nothing wrong with the big ends,,,so it will live again, that`s for sure) however, it`s not an engine you`d want to throw all your money at, "IF" it was just going to throw a leg out of bed (IE:conrod through the block or something similar)
we have found the best receipe to be an age old prooven method that my dad designed years & years & years ago (approx 1969) & that has simply not changed for all that time & it`s as stated above for crank & block being offset ground to bore of 73mm & crank to 84mm stroke (pistons are my dad`s own design & are rock solid bullet proof items & avalable from him (Jack) at ReadSpeed MiniMecca -ph-(07) 3245 2384 Chandler, Brisbane)
very carefull engine assy , paying close attention to all clearances & allowing more clearance to the lower center main cap thrusts to allow the crank to flex without pushing on the main cap ,,,& a decent cyl head set up to large inlet valves & std exhaust valve sizes with 9.5:1 or maybe up to 9.8:1 compression ratio for road engines (with re-shaped, de-shrouded & pollished chambers & running electronic ignition dist set up with the correct ign curve) ,,,we run up to 13.7:1 on race engines with this same sort of build, only fitting a huge race head & cam & SC/CR gearbox & all other race related gear tho
sorry but my fingers are now getting very sore tips on em,,,so i`ll say ta ta for now,,,any more info you need just type here & i`ll reply again soon
I would suggest that you get someone who "KNOWS" how to build performance mini engines to build it for you tho,,,lots of money to throw away if you do something a little "stupic"
& please make sure you spend more money on the engine that you think you need to,,,it`s allways a good thing to spend more on the internals of the donk than spending it all on pretty valve caps & shiny tow balls & fuzzy dice hangin off the mirror ,,,if you know what i mean
Oh!!!...& also please have some decent disc brakes fitted
