engine and box combinations... https://ausmini.com/forums/viewtopic.php?f=5&t=9916 |
Page 1 of 2 |
Author: | IwannaMini [ Tue Aug 09, 2005 8:44 am ] |
Post subject: | engine and box combinations... |
is it possible to put an old puddle stick gear box onto a 1275 engine..?? |
Author: | Spaceboy [ Tue Aug 09, 2005 4:45 pm ] |
no, and stop thinking about it ![]() |
Author: | GT1360 [ Tue Aug 09, 2005 7:02 pm ] |
moved from conversions to the right area... ![]() |
Author: | drmini in aust [ Tue Aug 09, 2005 7:16 pm ] |
Post subject: | Re: engine and box combinations... |
IwannaMini wrote: is it possible to put an old puddle stick gear box onto a 1275 engine..??
Of course it is! I even married a 1962 850 case to an 1100S motor, once... I cut 4 holes in the front of the case. I think I then used about 200ml of Araldite... ![]() But use a later case, no hole cutting needed.. why not use a 4 synchro (Mini-K, or Mk2 S) box and put the puddin' stirrer shift & diff housing into that... ![]() |
Author: | Spaceboy [ Tue Aug 09, 2005 7:19 pm ] |
drmini in aust wrote: IwannaMini wrote: is it possible to put an old puddle stick gear box onto a 1275 engine..?? Of course it is! I even married a 1962 850 case to an 1100S motor, once... I cut 4 holes in the front of the case. I think I then used about 200ml of Araldite... ![]() But use a later case.... why not use a 4 synchro (Mini-K, or Mk2 S) box and put the puddin' stirrer shift & diff housing into that... ![]() nooooooooooooooo! |
Author: | drmini in aust [ Tue Aug 09, 2005 8:07 pm ] |
WTF not??? ![]() Just need to check the diff bearing bores are right size & aligned, with an 850 diff housing on... ![]() Lotsa people did the opposite swap, back in the swingin' 60s... ![]() Sure it won't be as well mounted as a remote box, but it's absolutely no worse than any rod change... ![]() |
Author: | gafmo [ Tue Aug 09, 2005 10:59 pm ] |
I must admite I drove a wand..(Toby) for a week and loved it...a it more grund would have been realy nice ![]() |
Author: | IwannaMini [ Tue Aug 09, 2005 11:23 pm ] |
gafmo wrote: I must admite I drove a wand..(Toby) for a week and loved it...a it more grund would have been realy nice
![]() Now youre thinking just like me..!!! ![]() OK doc will have to talk to you more about this one... like a plane over Sydney most of that went straight over my head. But knowing that its possible has made my day. |
Author: | gafmo [ Tue Aug 09, 2005 11:31 pm ] |
Author: | Lillee [ Wed Aug 10, 2005 12:47 am ] |
Just get yourself a 4synchro remote box, they are the bees knees! ![]() |
Author: | IwannaMini [ Wed Aug 10, 2005 9:00 am ] |
I would love to get a 1400 turbocharged engine with dog box, or rip the thing to shreds and put a starlet engine with twin turbos or something as similarly out there, but at the end of the day, my van is a limited model and I love the thing to bits, so I am trying to search out the best way of keeping it looking nice and stock and original (ie keep the puddle stick) but give him a little more OOMPH (ie swap the engine for a 1275 and the drums for Cooper discs)... It will also mean that if I play my cards right and do it properly that I can put him on heritage plates and get him all ready for the MCC cruises and shows... |
Author: | GT1360 [ Wed Aug 10, 2005 9:32 am ] |
IwannaMini wrote: I would love to get a 1400 turbocharged engine with dog box, ...
Got a problem with that ![]() ![]() |
Author: | Harley [ Wed Aug 10, 2005 12:42 pm ] |
The problem is that if you damage the pudding stick shift from having too much power/torque from the 1275, you might be in for a bastard of a time getting parts again. Why not super or turbo the original engine for the box? |
Author: | IwannaMini [ Wed Aug 10, 2005 5:30 pm ] |
Harley wrote: The problem is that if you damage the pudding stick shift from having too much power/torque from the 1275, you might be in for a bastard of a time getting parts again.
Why not super or turbo the original engine for the box? I have 3 pudding stick boxes in the garage. One in the car. One on an engine. One just the box.... there is a few years playing... ![]() In all seriousness though, if its too much power I will look at seeing what I can do with the 998 thats in there now. Cant turbo charge etc because as above, I want to make sure I can stick to heritage plates... either way I have a couple months up my sleeve so I will work out what to do to the box to support the torque (or to see if I can modify a puddle stick to a more sturdy box) or what I can do to the engine to give it more power and reliability without taking away from the originality. ![]() |
Author: | fuzzy-hair-man [ Wed Aug 10, 2005 5:59 pm ] |
what makes a pudding stirer weaker than other gearboxes ![]() ![]() |
