Interference Engine? https://ausmini.com/forums/viewtopic.php?f=5&t=99085 |
Author: | Rosebud [ Thu Aug 29, 2019 11:27 am ] |
Post subject: | Interference Engine? |
Q: Is the A+ motor an interference engine? In other words, is it possible for the valves to come into contact with the pistons? I have 10:1 compression, a fast road cam, 1.5 rockers, and a standard profile crank. If my timing chain breaks or I experience valve float, will my valves hit the pistons? |
Author: | awdmoke [ Thu Aug 29, 2019 9:58 pm ] |
Post subject: | Re: Interference Engine? |
Most likely yes, not knowing your cam and pistons. If you were to break a double row timing chain then you have bigger problems. Valve float isn't one of them. |
