It is currently Sat Jun 21, 2025 7:20 am
 Post subject: Re-Sleeved Cylinders
PostPosted: Fri Aug 23, 2019 5:04 pm
I've got a Cooper S Mk11 block, cylinders 1 and 4 have already been sleeved. The number 1 sleeve is not level with the deck, it sits about 1 to 2 mm below the deck. Not sure sure how this happened. Is there any drama with using it as is or can the old sleeves be pushed out and the cylinders re-sleeved again. I'm at the stage of wondering what to do with reconditioning it. Any suggestions would be appreciated. I'm only new to the world of computers so I might be a bit slow to respond, thanks in advance, John
 Post subject: Re: Re-Sleeved Cylinders
PostPosted: Fri Aug 23, 2019 10:07 pm
Hi, what you need to look at is down the bottom of the sleeve (crank end) is there a line around the inside say 5mm or so from the bottom where the sleeve may have been stepped into the block (this stops it falling out the bottom) or can you actually see the thin sleeve at the bottom.
If you can see the sleeve, then one of them has dropped down ,and I would replace both.
A good quality engine reconditioner can fix it. (I emphasise quality ,as it is precision work)
Where do you live ?
cheers Lindsay Siebler
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
PostPosted: Sat Aug 24, 2019 7:56 am
Noting that there are a few Mini savvy people around Forbes, Cowra, Young etc but it might be best to put your block on a pallet and send it to a trusted machine shop closer to Sydney :idea:
PostPosted: Sat Aug 24, 2019 9:27 am
Or Canberra, where Belconnen Engine Centre has had quite a deal of experience in such matters.
PostPosted: Mon Aug 26, 2019 6:02 pm
Thanks for the info guys, still not sure where or what I'll be doing at this stage but just starting to think about it will be a while yet before I get to the engine, just doing the paintwork at the moment now the weather is getting better, cheers John
PostPosted: Mon Aug 26, 2019 6:12 pm
I lived Nthside for over 25 years...would love to see you expand on "quite a deal of experience in such matters" :D
