Turbo time https://ausmini.com/forums/viewtopic.php?f=5&t=98682 |
Page 1 of 3 |
Author: | Chris.Williams [ Fri Jun 14, 2019 8:09 am ] |
Post subject: | Turbo time |
Just removed my supercharger etc and moved into a turbo setup. |
Author: | simonw [ Fri Jun 14, 2019 10:14 am ] |
Post subject: | Re: Turbo time |
That sounds$s like fun . What prompted the move ? Sent from my iPad using Tapatalk |
Author: | Chris.Williams [ Fri Jun 14, 2019 11:00 am ] |
Wanted more control over the power output, without the need to change pulleys. Got offered good money for my kit, couldn’t say no. I originally wanted to turbo, but went with the supercharged option as it came as a kit. |
Author: | simonw [ Fri Jun 14, 2019 3:14 pm ] |
Look forward to the build ! Sent from my iPad using Tapatalk |
Author: | Chris.Williams [ Tue Jun 18, 2019 5:24 am ] |
Things are moving along, ordered a maniflow 2” exhaust system, turbo fuel pressure reg, Gt1752 turbo, and an Avonbar turbo electronic dizzy......keeping things simple. Cylinder head has been finished at engine shop. New stainless MED race valves, 35.7/31, new bronze guides and full race porting. Chambers, at this stage are 25cc. New GR266SS cam is on its way here from Graham Russell, looking forward to that bit for sure. Still on the hunt for a turbo hif44, May end up just buying it new. |
Author: | Scoop [ Tue Jun 18, 2019 7:11 pm ] |
Hi Chris, I have a mate that has one and was considering selling it. I will see him Saturday and find out for sure. Cheers |
Author: | Chris.Williams [ Tue Jun 18, 2019 8:26 pm ] |
Scoop wrote: Hi Chris, I have a mate that has one and was considering selling it. I will see him Saturday and find out for sure. Cheers Hey that would be awesome, thanks heaps |
Author: | Chris.Williams [ Wed Jun 19, 2019 8:46 pm ] |
Collected my cylinder head today |
Author: | Chris.Williams [ Thu Jun 20, 2019 12:10 pm ] |
Camshaft arrived today |
Author: | Kennomini [ Thu Jun 20, 2019 4:34 pm ] |
Do you need to cut and box the firewall with that setup? |
Author: | Chris.Williams [ Thu Jun 20, 2019 5:17 pm ] |
Kennomini wrote: Do you need to cut and box the firewall with that setup? No, it’s called a low mount setup, no need to cut and box. |
Author: | Kennomini [ Fri Jun 21, 2019 4:30 pm ] |
Cool, is their any concern about extra heat on the firewall? |
Author: | Chris.Williams [ Fri Jun 21, 2019 5:31 pm ] |
Kennomini wrote: Cool, is their any concern about extra heat on the firewall? There has been no mention of it, but I’ll be applying some protective heat shielding to be safe. Considering a turbo blanket, doing more research first. |
Author: | timmy201 [ Fri Jun 21, 2019 5:38 pm ] |
Do you want/need a metro turbo plenum for the carb? |
Author: | Chris.Williams [ Fri Jun 21, 2019 9:30 pm ] |
timmy201 wrote: Do you want/need a metro turbo plenum for the carb? No I have a Fusion Fabs one coming with the manifold. Still need the carb tho ![]() |
Page 1 of 3 | All times are UTC + 10 hours |
