https://ausmini.com/forums/
SC Blow Thru...Brilliant
https://ausmini.com/forums/viewtopic.php?f=5&t=98391
Author:  9YaTaH [ Sat Mar 23, 2019 6:16 pm ]
Post subject:  SC Blow Thru...Brilliant
Just wonder if the Turbo would cause a hot spot that close to the block...
https://www.youtube.com/watch?v=h1GaMqj1Gkk
https://www.specialist-components.co.uk/
[EDIT: link changed :-(]
Author:  Kennomini [ Sun Mar 24, 2019 8:28 am ]
Post subject:  Re: SC Blow Thru...Brilliant
(Technically not a turbo) But no it shouldn't cause a hot spot as it's the exhaust of the Turbo that is the biggest heat trap, this dose not have that. It will be hot/warm to the touch from compressing air (touch your air compressor at home) but should be fine in that location.
It will also get lots of air flow from the grill to the radiator to keep it cooler.
Author:  9YaTaH [ Sun Mar 24, 2019 3:57 pm ]
Tah...love the throttle response...sweet :-)
