Ring Gap on Forced Induction https://ausmini.com/forums/viewtopic.php?f=5&t=96206 |
Author: | Besser [ Mon Oct 23, 2017 4:09 pm ] |
Post subject: | Ring Gap on Forced Induction |
Ok, Based on a roots supercharger filling the cylinders of an 8.3:1 1275cc, no (limited) after(inter) cooling, what gap specs would be best for cast pistons? Im expecting to be running rather hot. |
Author: | GR [ Tue Oct 24, 2017 6:34 am ] |
Post subject: | Re: Ring Gap on Forced Induction |
Hi Besser .010 to .012 thou for the top ring and .014 to .016 thou for the second ring compression ratio 9.5 to 10 to one and 10 LB boost Graham Russell |
Author: | Morbo28 [ Sun Dec 03, 2017 8:47 am ] |
GR wrote: Hi Besser Hi Graham, would you recommend the same gaps on a std static compression 998? (with as much boost as it will comfortably handle on 98 octane and meth injection).010 to .012 thou for the top ring and .014 to .016 thou for the second ring compression ratio 9.5 to 10 to one and 10 LB boost Graham Russell Sent from my Pixel 2 XL using Tapatalk |
Author: | GR [ Sun Dec 03, 2017 6:26 pm ] |
Hi Morbo28 That will work fine on your 998. Graham russell |
Author: | Morbo28 [ Mon Dec 04, 2017 6:17 pm ] |
GR wrote: Hi Morbo28 Thanks GR, much appreciatedThat will work fine on your 998. Graham russell Sent from my Pixel 2 XL using Tapatalk |
Author: | Ian_B [ Thu Dec 14, 2017 7:16 pm ] |
I had a six cylinder turbo 202 torana Suck thru Double standard horsepower on a TO3 Garret turbo .Water methanol injection. Bottom end was standard and never broke a thing but shocked some people. Dyno man was not BS He said I know what a good standard one does and dont know my dynoes accuracy . He said yours does double. ![]() |
