It is currently Sat Jun 21, 2025 1:42 am
 Post subject: Timing Chain Breather
PostPosted: Wed Dec 20, 2017 10:03 am
I'm running a slight vacuum in the sump and looking for thoughts on deleting the timing cover breather on the A+.
PostPosted: Wed Dec 27, 2017 7:16 am
I'll bite. :)
Most all 1275 A series don't have one there. And if it's in an Oz roundnose body you would have to beat the crap out of it for clearance.
I have connected the flywheel housing breather to the rocker cover and run from this to a Toyota PCV valve on the Weber manifold. It pulls a slight vacuum too.
