Camshaft removal on A+ https://ausmini.com/forums/viewtopic.php?f=5&t=94768 |
Author: | EKLeigh [ Mon Jan 30, 2017 12:00 pm ] |
Post subject: | Camshaft removal on A+ |
Ok..... So what am I missing?? Trying to remove camshaft from A+ 1275 Head off Timing case off Disy out Disy drive pulled half out Push rods out How to remove lifters????? Is there a retainer at rear of camshaft/oil pump????? Thanks Sent from my iPhone using Tapatalk |
Author: | EKLeigh [ Mon Jan 30, 2017 12:03 pm ] |
Post subject: | Re: Camshaft removal on A+ |
Looks like motor must separate from gearbox, turn upside down to release lifters, pull cam, then access to lifters???? Sent from my iPhone using Tapatalk |
Author: | simon k [ Mon Jan 30, 2017 4:24 pm ] |
to remove them, you don't need to remove the gearbox, just gotta turn it upside down, then take the camshaft out, turn it back over and shake it a lot. They'll come out of the sump plug hole eventually... Unfortunately it takes an awful lot of very lucky shaking to get them back into the right spot |
Author: | EKLeigh [ Mon Jan 30, 2017 5:11 pm ] |
simon k wrote: to remove them, you don't need to remove the gearbox, just gotta turn it upside down, then take the camshaft out, turn it back over and shake it a lot. They'll come out of the sump plug hole eventually... Unfortunately it takes an awful lot of very lucky shaking to get them back into the right spot Hahahah Gold Sent from my iPhone using Tapatalk |
