Flare experts congregate https://ausmini.com/forums/viewtopic.php?f=5&t=94469 |
Author: | Alexw [ Sat Dec 24, 2016 10:16 am ] |
Post subject: | Flare experts congregate |
I have a set of flares that I've inherited, and I'm almost ready to fit them. They are fibreglass, and it's reasonably clear which are the fronts and rears (fronts have a wider flare at the bumper end) The fronts look like they will fit properly, but the rears look wrong. The radius of the flare seems too large at the rear - see pictures. Note that the pictures are not of the mini that they will be fitted to! front: ![]() rear: ![]() Anyone had experience here before? Thanks all |
Author: | zulu_warrior1976 [ Sat Dec 24, 2016 10:24 am ] |
Post subject: | Re: Flare experts congregate |
Could they be for 13's? On a mini that has had its guards cut? |
Author: | simon k [ Sat Dec 24, 2016 9:54 pm ] |
your pictures are too small to see clearly, but they look like a set of flares I have in my collection... the rear sits down on the bumper seam and they sit pretty low, below the seam over the wheel arch |
Author: | Alexw [ Sun Dec 25, 2016 7:46 pm ] |
They are a bit small. here is larger: Front ![]() Rear ![]() Not sure what you mean by low - if they are installed with the two ends in the right place, then the middle will be 30+mm lower than the original arch.. It's like the radius is just wrong. Alternatively, what flares to people recommend getting that add around 40mm of width? Cheers |
