Albino_Hedgehog wrote:
Hello,
I currently have an MG 1100 engine that is completely standard except for an MG Metro Cam swap.
I was wondering what work I would need to do to fit as supercharger kit built by The Car Kitchen.
The engine has just been rebuilt to standard specification, the bores have not changed etc.
Would I be able to fit this kit and then drive it away?
Hi my name is matt I am travelling around Australia with my mini arm.
As for your supercharger to 1100 trial , it would work and you could drive it away , put two extra studs in your head upgrade the head gasket and your ignition synonym and away you go . Not everything will last as long that's you'll have to strip it down more often just upgrade a few parts then
