It is currently Sun Jun 29, 2025 7:11 am
 Post subject: 998 with 1100 crank?
PostPosted: Mon Jul 25, 2005 7:29 pm
I Rebulit an 998 12 mouths ago only did 2500 ks and replaced it with a rebulit 1330 a++++.
Now we have the travller i will put the 998 in it , but i also have an 1100 crank sitting around .
Would i be able to fit the 1100 crank to the 998 if i get it re ground[10/10] and is there anything els i would need to do?
I swerve and hit people at random.
PostPosted: Mon Jul 25, 2005 7:41 pm
Should go straight in except you'll need to change the rods. Pistons too?
PostPosted: Mon Jul 25, 2005 7:43 pm
Crank will go in, use your 998 rods (exactly the same) but you need 1098 pistons. Pin to crown height is different by 0.148". 8)
Good mod- gives it something 998s don't have... TORQUE! :lol:
PostPosted: Mon Jul 25, 2005 8:28 pm
THANKS GUYS .
Will I need 1100 pistons & rings to suite the bor [+20]
If so I found sum Hypatec pistons & rings on ebay for $175.00 new what are your thoughts ?
PostPosted: Mon Jul 25, 2005 8:58 pm
Yep Hypatecs are good. Better than most other 1098s pistons still available, IMO. :wink:
PostPosted: Mon Jul 25, 2005 9:39 pm
That's what I'm running at the moment, and it does make a difference. Get yourself a 12g295 head, and you will notice even better performance. :D .........Oh! Just so happens I have one here you can buy....just needs new valves :wink: Will let it go with a decent offer 8)
PostPosted: Mon Jul 25, 2005 9:44 pm
Thanks scotty but I have one on with new valves ulp and ported ready to go.
