https://ausmini.com/forums/
8.4 to 7.5 inch disc brake conversion
https://ausmini.com/forums/viewtopic.php?f=5&t=94259
Author:  JC69 [ Sun Nov 20, 2016 2:36 pm ]
Post subject:  8.4 to 7.5 inch disc brake conversion
Hi
I would like to swop my 8.4" discs for 7.5" system so I can run 10inch rims
On my Mini K. I haven't had the car too long a few months so I didn't add the
8.4 inch brakes myself. I am considering just buying the discs, calipers and drive flanges
Does that sound sensible or should I purchase the whole 7.5 system ? Is there any
specific parts that could be worn out on the old system that I should be careful of ?
If I go down the part replacement route have I missed any parts from my shopping list ?
Thanks
Jason
Author:  andrew9 [ Sun Nov 20, 2016 3:05 pm ]
Post subject:  Re: 8.4 to 7.5 inch disc brake conversion
I think you can machine down your current rotors and use certain calipers, not sure if Cooper S caliper would work.
KAD 4 spots for 10" wheels are are based on vented 8.4 disks machined down with their calipers, but I'm not sure what other calipers might work
Or:
http://www.minispares.com/product/Class ... 013MS.aspx
Author:  1071 S [ Sun Nov 20, 2016 6:15 pm ]
Do I read that correctly :shock: MS calipers are UKP150 odd cheaper than the "genuine" (???) S version?
Cheers, Ian
Author:  simon k [ Sun Nov 20, 2016 7:34 pm ]
that's all you need, and pads obviously
edit: here's the kit, up to you whether it's best to replace everything... the upside of that is that everything is new, but $$ may be better spent elsewhere
http://minispares.com/product/Classic/B ... 0to%20shop
edit: oops, sorry Andrew, I saw the link in your post but forgot...
Author:  Phil 850 [ Sun Nov 20, 2016 8:23 pm ]
I got my kit from Karcraft, but I'm sure any mini parts suppliers can do a kit for you.
I only replaced the bits I needed to.
Author:  JC69 [ Mon Nov 21, 2016 12:16 pm ]
Thanks for the advice guys
Author:  peterb [ Mon Nov 21, 2016 5:24 pm ]
dont forget rear cylinders.
