https://ausmini.com/forums/
Head gasket recommendation for 998 80 thou over
https://ausmini.com/forums/viewtopic.php?f=5&t=94082
Author:  ClintW [ Thu Oct 27, 2016 2:18 pm ]
Post subject:  Head gasket recommendation for 998 80 thou over
Hi all, having a head gasket issue on 998 .080" oversized bore. Blowing the gasket between 3&4. Anyone recommend what head gasket to use. Thanks.
Author:  Scoop [ Thu Oct 27, 2016 4:40 pm ]
Post subject:  Re: Head gasket recommendation for 998 80 thou over
Make sure that both the head and block surfaces are dead flat. Type of gasket unsure though, ACL used to be the go but they are no longer made
Author:  69k1100 [ Thu Oct 27, 2016 7:13 pm ]
http://www.youtube.com/watch?v=XEaRMR-RZPo
Janspeed thought fuse wire could sort the issue, never really heard of this working first hand.
Author:  drmini in aust [ Thu Oct 27, 2016 9:36 pm ]
I used a 1275 gasket on a 68mm bore 998 with a 12G202 head, but a few water holes had to be moved in head and block.
Author:  ClintW [ Fri Oct 28, 2016 8:32 am ]
Thanks for the advice. Might explore the 1275 option further. I've heard that they will fit with some modification to align water jacket
