https://ausmini.com/forums/
1275 A+ engines
https://ausmini.com/forums/viewtopic.php?f=5&t=9401
Author:  Harley [ Sat Jul 23, 2005 8:55 pm ]
Post subject:  1275 A+ engines
Hey, recently acquired a 1275 A+ engine, does it use the same carbs and
extractors as my 1100?
What else can I use? Starter motor, water pump?
They all look like they'll fit, but would it run into problems?
Thanks.
Author:  drmini in aust [ Sat Jul 23, 2005 9:01 pm ]
Everything fits on. Even a Pulsar dizzy (but you have to fit an A+ drive dog).
I've got a 1293A+ in Barney.
The last of the 1275 Mokes here got them. :wink:
Author:  Harley [ Sat Jul 23, 2005 9:07 pm ]
That's cool.
I got a new electronic dizzy with it. I'm all set.
Does your clutch setup work as normal? Mine is set up different.
For a cable?
Author:  drmini in aust [ Sat Jul 23, 2005 10:22 pm ]
Most people recommend that you fling the Metro cable setup if putting into a Mini. Mine has a MK2 S box and early clutch. Non verto... :P
Author:  scotty [ Sun Jul 24, 2005 8:31 pm ]
Love the rocker cover 8) Aquired the same one myself + temp sender for 10 bux!
