max RPM https://ausmini.com/forums/viewtopic.php?f=5&t=93785 |
Author: | oldblade [ Mon Sep 19, 2016 9:47 pm ] |
Post subject: | max RPM |
Can anyone tell me what the max RPM in general should be for a 1275 seems like a mild cam standard head bored to 1310 should be I engine seems to be happy to rev and 6000 RPM doesn't seem to be an issue. what did they rev to out of the box? |
Author: | gtogreen1969 [ Mon Sep 19, 2016 9:52 pm ] |
Post subject: | Re: max RPM |
I used to rev my Cooper S to 35mph in first, 56mph in second and 77mph in third. Just as the speedo says. No idea what rpms but. No tacho |
Author: | oldblade [ Mon Sep 19, 2016 10:00 pm ] |
gtogreen1969 wrote: I used to rev my Cooper S to 35mph in first, 56mph in second and 77mph in third. Just as the speedo says. No idea what rpms but. No tacho I have the opposite problem MPH is not accurate and I have a smiths RPM gauge so it's closer to accurate |
Author: | gtogreen1969 [ Mon Sep 19, 2016 10:04 pm ] |
My last mini was a worked 1330 with Cooper S internals and it went to 6500rpm easily but ran out of grunt if you took it to 7000rpm. |
Author: | oldblade [ Mon Sep 19, 2016 10:15 pm ] |
cool I have the RPM limiter set to 6500 so I might have it about right |
Author: | drmini in aust [ Mon Sep 19, 2016 10:55 pm ] |
HP peak was at 5,800rpm, so 6500 is OK. HP is diving by 7000. |
Author: | winabbey [ Mon Sep 19, 2016 11:03 pm ] |
viewtopic.php?f=2&t=91129 |
Author: | slacko [ Mon Sep 19, 2016 11:17 pm ] |
My motor is a near stock mk1 1275 30th over bore and an old 266 cam grind it made max torque at 5000 and max horse power at 6000 I have my red line set at 5500 for day to day driving not that I don't take it to 6500 or more every now and again ![]() |
Author: | oldblade [ Tue Sep 20, 2016 6:40 am ] |
Thanks, i'll have to get mine on a Dyno and set it correctly but his has provided me with a good round about number |
Author: | 9YaTaH [ Tue Sep 20, 2016 7:08 am ] |
oldblade wrote: Thanks, i'll have to get mine on a Dyno and set it correctly but his has provided me with a good round about number I wouldn't be using six and half grand on a round about... ![]() (better to be near peak torque...) |
Author: | oldblade [ Tue Sep 20, 2016 7:32 am ] |
It's just used for the Rev limiter on my dizzy Sent from my Nexus 6P using Tapatalk |
Author: | drmini in aust [ Tue Sep 20, 2016 7:39 am ] |
oldblade wrote: It's just used for the Rev limiter on my dizzy Sent from my Nexus 6P using Tapatalk My black box rev limiter is set at 7500, because my HP peaks at 7000 or so. Not that I go there often... ![]() |
Author: | oldblade [ Tue Sep 20, 2016 4:38 pm ] |
Just had a play with my black box hmmmm and now set the max rpm to 6500 I checked and had it at 6000 by accident also made a couple of other changes. Think I found a few Horses Sent from my Nexus 6P using Tapatalk |
