https://ausmini.com/forums/
Help wet spark plug
https://ausmini.com/forums/viewtopic.php?f=5&t=93640
Page 1 of 3
Author:  oldblade [ Thu Sep 01, 2016 6:11 pm ]
Post subject:  Help wet spark plug
Help I was driving normally next minute the carbies splutter and start making louder then normal flutter sounds and I loose power when I get check it out to find my exhaust was loose (easy fix) but th car still running like a pig I remove the spark plugs and second from the left is wet with fuel
I run the colortune to check I have spark on that cylider and I do
Check the coil with a mulitimeter (not a great way I know) getting17.5
This morning on the way to work at a out 4500rpm on the freeway I dealt a flutter
Before buying anothe coil which is olny a month old has anyone got any ideas
Author:  Phil 850 [ Thu Sep 01, 2016 8:03 pm ]
Post subject:  Re: Help wet spark plug
If it's only one cylinder, wouldn't it be the lead or plug ?
Author:  oldblade [ Thu Sep 01, 2016 8:24 pm ]
that was my guess so I swapped both and the wet plug didn't come back though it still ran like a dog
After leaving it for a while idling plug wet again
If I remove lead 2 and 3 the engine still runs Baddly but runs. If I remove 1 or 4 it dies
If 2 or 3 are disconnected the engine runs badly telling me it using those cylinders the knock knock knock from the carbs is confusing me. wish I could record it
could it be a valve ? I removed the rocket cover and could see anything obvious
Author:  Minicooper4me [ Thu Sep 01, 2016 9:40 pm ]
Maybe something simple like a crook lead but it does sound like a valve or head gasket. Either way, the head will have to come off. Have you done a recompression test ?
Author:  oldblade [ Fri Sep 02, 2016 6:46 am ]
I was thinking the head might have to come off bugger
Author:  drmini in aust [ Fri Sep 02, 2016 7:05 am ]
Check the resistance of the plug and coil leads.
If over 5K ohm I would bin them. When cheap leads get old the resistance goes up, they get internal breaks in the core.
If buying new, get inductive core leads, not graphited string cheapy ones.
I use Bosch, but Graham Russell has tailored to fit Mini sets using similar cable.
Author:  9YaTaH [ Fri Sep 02, 2016 8:11 am ]
Whoa!! Exhaust all normal reasons for wet plugs like lack of spark before diving into major surgery! Did you fit an electronic distributer? Have you checked all the HT leads and their connections including the coil? Plugs don't last forever these days...etc etc
Author:  oldblade [ Fri Sep 02, 2016 10:46 am ]
Plugs replaced I am running electronic ignition new leads new coil about a month old
Why do you say exhaust ? It does have a leak at a join mid way down and it appeared at the same time
Author:  timmy201 [ Fri Sep 02, 2016 10:57 am ]
exhaust
ɪɡˈzɔːst,ɛɡ-/
verb
1.
make (someone) feel very tired.
"her day out had exhausted her"
synonyms: tire out, wear out, overtire, overtax, fatigue, weary, tire, drain, run someone into the ground, run someone ragged, enervate, sap, debilitate, prostrate, enfeeble; More
2.
use up (resources or reserves) completely.
"the country has exhausted its treasury reserves"
synonyms: use up, run through, go through, consume, finish, deplete, expend, spend, dissipate, waste, squander, fritter away; More
Use up (exhaust) all normal reasons...
Author:  oldblade [ Fri Sep 02, 2016 11:38 am ]
So you saying it could make it run that badly
Author:  timmy201 [ Fri Sep 02, 2016 12:11 pm ]
9YaTaH wrote:
Whoa!! USE UP all normal reasons for wet plugs like lack of spark before diving into major surgery! Did you fit an electronic distributer? Have you checked all the HT leads and their connections including the coil? Plugs don't last forever these days...etc etc
I've removed the word exhaust from the comment above. It was not used to describe the waste gases from an engine.
Author:  simon k [ Fri Sep 02, 2016 12:16 pm ]
does it sound like a tractor?
my bet is head gasket popped between 2 and 3
I'd just about stake my left nut on it
Author:  oldblade [ Fri Sep 02, 2016 12:20 pm ]
Yeap it does
I'll rip the head off and check I have a feeling the head gasket was iffi as I saw water marks down the front of the engine looking like it was coming from the head
Does anyone have the torque settings for the head bolts?
Author:  drmini in aust [ Fri Sep 02, 2016 2:19 pm ]
Head nuts on an S are 42ft/lb, but the small bolt near the thermostat is 25ft/lb.
Before pulling the head, do a compression test.
If you don't have a tester, crank it with plugs out and put yer thumb on the plug holes. If no pressure on 2 and 3, the gasket is blown between. If all feel equal I'd leave the head on it.
Author:  AWOODY [ Fri Sep 02, 2016 2:59 pm ]
Anthony , what have you done to my car ?( only joking ) I have a compression tester but I probably live too far away . Grant.
Page 1 of 3 All times are UTC + 10 hours
