It is currently Sun Jun 29, 2025 4:41 am
 Post subject: 1275 A+ engines
PostPosted: Sat Jul 23, 2005 8:55 pm
Hey, recently acquired a 1275 A+ engine, does it use the same carbs and
extractors as my 1100?
What else can I use? Starter motor, water pump?
They all look like they'll fit, but would it run into problems?
Thanks.
PostPosted: Sat Jul 23, 2005 9:01 pm
Everything fits on. Even a Pulsar dizzy (but you have to fit an A+ drive dog).
I've got a 1293A+ in Barney.
The last of the 1275 Mokes here got them. :wink:
PostPosted: Sat Jul 23, 2005 9:07 pm
That's cool.
I got a new electronic dizzy with it. I'm all set.
Does your clutch setup work as normal? Mine is set up different.
For a cable?
PostPosted: Sat Jul 23, 2005 10:22 pm
Most people recommend that you fling the Metro cable setup if putting into a Mini. Mine has a MK2 S box and early clutch. Non verto... :P
PostPosted: Sun Jul 24, 2005 8:31 pm
Love the rocker cover 8) Aquired the same one myself + temp sender for 10 bux!
