Hi H
Can I buy complete gasket and rubber mount kits
Yes - any mini supplier can sort you out with a set to suit what you are doing be it just taking off the head or doing a complete strip down.
Is liquid gasket in any way preffered to the other kind?
Don't know about others but my mech used all the paper gaskets AND the gasket sealant on all the joints. I comes down to how fond are you of oil leaks in the driveway? seal them well and they don't leak.
Also, what does an 1100 engine and gearbox weigh approximately?
Sorry NFI but I would think you would be safe at under 160kg
[I would guess at around 120 but maybe someone else may have more detail available]
Do I have to remove the driveshafts, or can I get round that?
You disconnect the driveshafts at the inner joint [either pot joint or one of the variants of a uni-joint]. The drive shafts themselves do not need to be removed from the wheel hubs to effect the engine removal.
Feel free to check out my project site where
Donkey's new motor is installed for any visual pointers that it may give you.
Good luck with your project.
Cheers Dat
