turbo pistons and head https://ausmini.com/forums/viewtopic.php?f=5&t=9071 |
Page 1 of 2 |
Author: | mini_matt [ Thu Jul 14, 2005 7:00 pm ] |
Post subject: | turbo pistons and head |
alright every thing else is set but pistons and or head mods for the turbo motor. sugestions what pistons to use ( 20 thou so availibility) hoping to drop comp under 9 slightly so whats pistons and what size chambers . this ones gunna hurt the pocket. for the clubby estate |
Author: | kazjim [ Thu Jul 14, 2005 10:09 pm ] |
Throw us a little bone here.... 850?998?1100?1275?Bigger? J |
Author: | drmini in aust [ Thu Jul 14, 2005 10:31 pm ] |
If 1275 based I would use Hypatecs. They have plenty of meat in the crown, so you can make the dish bigger for more volume without hacking hell out of the combustion chambers... ![]() They are tuff enough that guys race with them. |
Author: | Boostedmini [ Fri Jul 15, 2005 11:23 am ] |
it also comes down to what you want out of it, if all out turbo i would go forged pistons as for head a good modded 12G940 will be fine, if you want to run more than 10psi i would lower comp down to 8 if not 7.5 |
Author: | TheMiniMan [ Fri Jul 15, 2005 2:20 pm ] |
JP-> 73mm pistons & BMW K1 Motorbke twin cam 16v cyl head ![]() sorry, couldn`t help it ![]() |
Author: | mini_matt [ Fri Jul 15, 2005 6:39 pm ] |
Post subject: | engine |
hypatecs sound good. dont think droppin the comp that low will be needed. wanna run bout 10 psi max on occasions. aslong as setup right should be fine. ![]() |
Author: | drmini in aust [ Fri Jul 15, 2005 7:10 pm ] |
I wouldn't use JP pistons in a turbo or any competition motor. Broke one once in a 1098 Mini and was not impressed with how it was cast... ![]() |
Author: | TheMiniMan [ Sat Jul 16, 2005 1:02 pm ] |
yeah Kev, the small bore JPs arn`t much good at all,,,YUK!!!...but the big bore 73mm ones are exccelleennnttttt!!!!!!!!!!!!!!!!! un-breako!!!!!!!! |
Author: | drmini in aust [ Sat Jul 16, 2005 1:32 pm ] |
TheMiniMan wrote: yeah Kev, the small bore JPs arn`t much good at all,,,YUK!!!...but the big bore 73mm ones are exccelleennnttttt!!!!!!!!!!!!!!!!! un-breako!!!!!!!!
Matt, Do tell- my mate Dave managed to bust the ring lands off a couple.. it was an NA motor too, no turbo... ![]() OK so it is an Nb racer, it revs to 8K... ![]() |
Author: | mini_matt [ Sat Jul 16, 2005 1:46 pm ] |
Post subject: | a |
so GR engineering my man for the pistons. what about getting them machined same place?? and i wanna get my cam reground GR as well if so what do ya recomend. cant wait for the clubby estate to be finished |
Author: | drmini in aust [ Sat Jul 16, 2005 2:48 pm ] |
GR sells Hypatecs, he can also mod their dish to whatever you want. And grind your cam... ![]() kazjim has one of his grinds in the 998 turbo... ![]() |
Author: | TheMiniMan [ Sat Jul 16, 2005 4:51 pm ] |
Kev,,,My old man put a heap of time in with the old guy (Frank) who used to work for Laurie at JP years ago, & they basically produced a pretty good piston from both the "S" one & the old datto 1200 one,,,then there were a few issues with the ring lands breaking very early in the peice as they were a little too close to the crown & a bit thin in the land,,,they then dropped all the rings down a fair bit & spaced the lands more to make them way thicker,,,we`re now on (i think) the 5th design piston & have stuck with it now for many many years,,,it`s pretty dam good & i don`t believe you can break em...,,,BUT!!!,,,,that piston design is only on the 73mm ones,,,i don`t think they have changed their """Normal""" 1275 & oversize pistons to that design tho i`ve run my 1415cc stroker speedway mini with those JPs in it up to 9000rpms nearly every sat night for about 4 years solid (with a "re-ring & bearing" job every year tho) & those pistons are still good & still in that same engine & is still quite a good runner, altho they do have a little more clearance now than they used to, but it`s because of that it`s still a good hard race donk ![]() It`s the small bore pistons that are no where near as good a design as the 73mm ones, i won`t use the small bore ones for that reason & i know heaps of people who bag the crapper out of em too & therefore , heaps of people feel that the big bore ones are bad also, add to that, is the ring lands cracking on the early-er 1275 pistons, end result was that JP ended up with a bad name for mini pistons because of all that,,,but i can assure you that the 73mm ones that my dad designed with Frank are actually the bees knees ![]() |
Author: | mini_matt [ Sat Jul 16, 2005 6:15 pm ] |
what do you reckon it'll cost me for pistons, mods and cam? whats the number i can contact GR on please |
Author: | Coop [ Sat Jul 16, 2005 8:45 pm ] |
what about ARIAS pistons they dont have pistons in stock that will fit a mini, but.... they can custom design a piston to your own specifications, forged, flat top, special insignias anything ! but its gana rip you a new ar$e |
Author: | drmini in aust [ Sat Jul 16, 2005 11:24 pm ] |
mini_matt, PM sent. Coop, sure... Arias (or Wiseco, or whoever) could make you some but unless you want a bunch of them it'll cost $$$big. ![]() |
