https://ausmini.com/forums/
Bias spring on remote
https://ausmini.com/forums/viewtopic.php?f=5&t=90044
Author:  69k1100 [ Fri Jul 24, 2015 9:19 am ]
Post subject:  Bias spring on remote
Has anyone (or is it possible) fit the bias spring for rod change cars to a remote extension so it will hold in neutral like a modern gearbox?
Author:  drmini in aust [ Fri Jul 24, 2015 12:29 pm ]
Post subject:  Re: Bias spring on remote
??? Assuming you want it to stay in the 3-4 plane. What rodchange Mini got a bias spring?
If you want to stop it jumping the reverse gate on fast 2-3 shifts, just fit a stronger reverse detent spring. I have a `red' die spring in mine for this purpose. It is under the gearbox hex plug behind the oil filter. If you have a reverse light switch there, you will need to make a thinner actuating plunger rod.
Author:  timmy201 [ Fri Jul 24, 2015 12:48 pm ]
Minispares sells them for rod change:
http://www.minispares.com/product/Class ... MSG12.aspx
