It is currently Mon Jun 23, 2025 6:16 am
PostPosted: Sun Aug 02, 2015 8:25 pm
What do the guru's use to install camshaft bearings ?, does anyone know were you can buy them ? , or are their any design I can copy. Cheers mal
PostPosted: Sun Aug 02, 2015 8:43 pm
hydraulic press
PostPosted: Sun Aug 02, 2015 9:06 pm
I was going to make on of these tools the next time I need to do the cam bearings.
I am sure if you search the web you can find some more drawings
http://www.3dcontentcentral.com/downloa ... &id=423572
Hope this helps
Kiwiinwgtn
PostPosted: Sun Aug 02, 2015 9:31 pm
Hope this helps
Kiwiinwgtn
Graham Russell uses a similar kit, not sure where he got it from. Works well. No press needed.
PostPosted: Sun Aug 02, 2015 9:39 pm
http://www.dummett.net/ime/website/ime/c/cam.html
the dimesions are listed here.
PostPosted: Wed Aug 05, 2015 7:46 pm
Surely you could machine up some press tools on your lathe malcom...
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Wed Aug 05, 2015 8:00 pm
Will be making up a set Friday
PostPosted: Thu Aug 06, 2015 1:11 pm
Ac
PostPosted: Sun Aug 09, 2015 9:41 pm
Well , I finished making installation tool for cam bearings today, very happy with the result , new bearings installed in race motor. 8)
