https://ausmini.com/forums/
On The Road Again
https://ausmini.com/forums/viewtopic.php?f=5&t=8954
Author:  Stuartminidlx [ Sun Jul 10, 2005 6:33 pm ]
Post subject:  On The Road Again
JUst a few Question. will cruising at 4000rpm over a long period of time cause damage. because i have got a 3.65 diff in now and a 4000rpm i'm doin 100km/h legal limit for green plater.
also i have fitted a 45mm webber and i am getting alot of fuel built up araound the air filter is this normal.
Author:  marcsvenson [ Sun Jul 10, 2005 6:36 pm ]
nah should be ok
Author:  FatMaserati [ Sun Jul 10, 2005 6:45 pm ]
It will only cause damage if your cooling system is shonky and/or you are using a really poor quality/brand of oil. If you plan on doing 100kmh for long periods quite frequently, then make doubly sure that oil/coolant levels are maintained and if it looks like it's getting to hot, then stop.
If you want to, then you could go for a different ratio final drive. I think I have a 3.44 in at the moment, but I want to get a 3.1 or something, just to make higher speed cruising a little more "comfortable".
Author:  drmini in aust [ Sun Jul 10, 2005 6:49 pm ]
Nah, 4000 won't hurt it. I run a 3.65 diff too- I put it in instead of the 3.44, to get even more grunt in 4th gear. :P
Actually a 1275 has a harmonic imbalance somewhere around 4500 I think, best to either go either faster or slower than that on the freeway.
So I've been told... but it never hurt my last S crank... :lol:
Author:  Stuartminidlx [ Sun Jul 10, 2005 9:38 pm ]
na i ditch my 3.44 there no fun. it's hold it's temp great on the highway but i think i will change my oil to castrol formular R.
Author:  Mini Mad [ Sun Jul 10, 2005 10:21 pm ]
You should have no probs, I don't know what you call long, but i do a 30-40min trip to work on the freeway and i vary speed between 100-130..about 4000-5250ish the whole way and it's never complained..
Overheating shouldn't be a problem on the freeway, I don't know about the 3.65 diff...i like the idea..but at hwy speeds it's probably too loud for my liking..
Author:  Stuartminidlx [ Mon Jul 11, 2005 10:59 pm ]
tell me about it i have 2inch all the way through to the cannon and the webber and my dash isn't sealed so it's very loud. i wear ear plugs for the trip to work. getting a muffler soon
