It is currently Sun Jun 29, 2025 3:06 am
 Post subject: Roll Cage Material
PostPosted: Tue Jul 05, 2005 7:33 pm
heya all, another question. this time about roll cages.
i have a alloy cage in betsy, but im thinking of building a steal one for my new project.
what would be the best stuff to use? thickness, size, etc.... has to be able to get a engineers certificate after construction.
any help much appreciated.
cheers, josh
PostPosted: Tue Jul 05, 2005 7:55 pm
I'm not sure about which stuff to use, but won't steel just add excessive weight?
Jonathan
PostPosted: Tue Jul 05, 2005 8:29 pm
Chrome-Moly Steel ....
Weldable, bendable and strong....
Big $$$ Though.... its the stuff Nascar Space-frames are made of :shock:
J
PostPosted: Tue Jul 05, 2005 8:36 pm
Cams rollcage material secs. are
Cold drawn seamless steel tensile strenght of 350MPA
Main hoop 44.5mm OD 2.5 wall
Other bars 38mm OD 2.5mm wall
These are for racing uses so road use may require different specs.
4efte powered Clubman
supercharged 998 race car
PostPosted: Wed Jul 06, 2005 10:12 am
Just to add to above, CDW (welded) or CDS(seemless) is OK.
CAMS have it all wrong here. Dick Johnson used good old Palmer Tube Mills (now Smorgan steel tube) pipe in his Sierras and these cares were shipped to Oz in half cuts, easier to ship.
The CDW and CDS is not made in Australia and has to be imported, expensive.
Good enough for Dick the Ozzie made 450 grade should be allowed but CAMS are knobs!!!
If its about protection why don't CAMS make the older log booked cars with alloy roll cages put the steel cagesin?
