It is currently Wed Jun 25, 2025 8:12 am
 Post subject: rod change bias barrel
PostPosted: Mon Nov 17, 2014 7:17 pm
recently purchased and fitted bias barrel ,followed instructions that came with it.when installed it won,t allow any movement of gear stick at all[side to side] has anyone fitted one of these? are there any traps to fitting them.it seems to me that the spring around the barrel is too tight and won,t allow spring to flex any help appreciated
snurkdog
16v, twin cam, 'a'series, cooper S replica,3x dcoe webers,Around 200 HP and heaps of torque
PostPosted: Mon Nov 17, 2014 9:05 pm
I tried fitting one of these barrels and had similar results to yourself. WHen I took the barrel back off of the rods, I could see marks in between the V of the spring ends. So with mine what was happening was the rod was fouling on the barrel itself, no matter where I placed it the same thing happened. I just took it off.
PostPosted: Tue Nov 18, 2014 8:26 am
Where did you buy the kit from? HAvew seen this with copies of the original design.
PostPosted: Tue Nov 18, 2014 10:39 am
http://minisport.com.au/mini-rod-change ... ias-barrel
This is the exact one I bought
PostPosted: Wed Nov 19, 2014 7:24 pm
yeah thats the same one,got it from minispares uk ,i emailed them but they don,t reply.who mentioned a copy?
PostPosted: Wed Nov 19, 2014 11:51 pm
i have mine, from minispares uk, fitted years ago, without problem. still working, tried today.
but that doesn't mean the quality today may not differ. or a bad batch is around.
can you check if it fouls anywhere? or if the spring is much to strong? you should be able to move the legs of the spring with some force
Rover 214 atm ....
PostPosted: Sun Nov 23, 2014 7:56 pm
can you recall if there is clearance between spring coils and the barrel itself , mine has no clearance which won,t allow the legs any movement,relies on bendng the legs rather than allowing the barrel to rotate within the spring,[thats how i see it]
PostPosted: Wed Nov 26, 2014 7:08 am
i would say yes, but will try to have a look next time i'm there
Rover 214 atm ....
