It is currently Thu Jun 26, 2025 1:48 am
 Post subject: Which 1275 to modify???
PostPosted: Sat Jul 12, 2014 5:13 pm
Hi guys, I have just picked up another moke for parts (collecting next weekend). So I will have 2 Californian mokes, both 1275 models, one is late 78 and the other is late 79. I think there is a difference between the engines, the earlier one is a thin flange block and the later one has a thick flange block.
I will keep one of the mokes original but will part the other one. To much rust to recover.
Which engine would be the better one to build a strong modified grunt box? Stroker 7 port or something.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Jul 12, 2014 6:34 pm
Either 1275 block will be fine.
Even a thin flange 1275 block is more rigid than a thick flange 1275S one.
PostPosted: Sat Jul 12, 2014 6:36 pm
Wouldn't you just keep the correct motor with the car your keeping original?
PostPosted: Sat Jul 12, 2014 6:42 pm
That is the preferred way I want to go.
5/72 Clubman Gt
PostPosted: Sat Jul 12, 2014 6:55 pm
Why would a late Californian have a thin flange block anyway?
PostPosted: Sat Jul 12, 2014 10:21 pm
78-79 both sound like late models to me wernt they started in 66 to be made
PostPosted: Sun Jul 13, 2014 8:37 am
Should they both be thick flange? Does anyone one now what engine prefix should be in it?
5/72 Clubman Gt
PostPosted: Sun Jul 13, 2014 8:40 am
They are both late mokes but are before the galv body. Both have fuel fillers on the top of the side box.
5/72 Clubman Gt
PostPosted: Sun Jul 13, 2014 8:48 am
All 1275 blocks from ~1969?-1970 on were thick flange. No idea of the engine numbers for a late 70s Moke though.
I believe the very last (~1981?) gal Mokes had a 1275 A+ motor, we put one in Barney the pretend S.
[edit] Barney's A+ motor was a 12H706AAZ one
Last edited by drmini in aust on Sun Jul 13, 2014 11:58 am, edited 1 time in total.
PostPosted: Sun Jul 13, 2014 9:06 am
I have a moke thick flange 1275 block in my 63 mini. It's engine number is 1204 ****. Not sure what year it is though.
1963 Morris 850
PostPosted: Sun Jul 13, 2014 10:44 am
The 1204 block is out of the Export Moke from 72-73.
The late Mokes from 78 to 82 with the 1275 motor have a 12H902 motor and maybe a 12H905 on the last ones. There might be another couple of prefixes as well.
A thin flange block is going to be a 12YD/Ta/H from 67/68.
PostPosted: Sun Jul 13, 2014 12:39 pm
PM John Sneddon on here. He has a full list of Mini and Moke body and engine number data.
PostPosted: Sun Jul 13, 2014 12:48 pm
From the Moke forum-
1275 engines in 1981 Mokes should have a 12H706AAZ engine prefix.
http://www.moke.com.au/Forum/index.php?topic=6150.0
PostPosted: Sun Jul 13, 2014 12:55 pm
Why would the prefix numbers suddenly go backwards? Especially backwards to an existing Mini 1275GT prefix? :mrgreen:
PostPosted: Sun Jul 13, 2014 1:18 pm
No idea, but the 706AAZ is an A+ block, the others are not.
Don't these UK sourced numbers just indicate the odds and ends fitted? eg alternator, emissions gear or not, etc?
[edit]
Seems common to late Mokes-
http://www.moke.com.au/australian-moke- ... ?start=270
