It is currently Sat Jun 28, 2025 3:04 pm
 Post subject: Weber 40 DCOE 32
PostPosted: Wed Jun 29, 2005 6:40 pm
would this Carb be overkill on a tricked out 998? or would it be just peerrrrfect :P
PostPosted: Wed Jun 29, 2005 9:11 pm
people here are running them (and 40-45 Dellortos) on 1098s so should be OK on a 998. Just need to rev its nuts a bit harder.. :lol:
PostPosted: Thu Jun 30, 2005 12:45 am
Ditto, Doc.
Jonathan
PostPosted: Thu Jun 30, 2005 8:54 pm
i dont think i like revin the nuts out of a 30 yr old engine i just want a good power curve with good torque down low and good power all the way to 5000 - 6000
PostPosted: Thu Jun 30, 2005 9:01 pm
If you want good torque down low on a 998, a Weber is not the ideal. I'd get an HIF44 SU and bung it on a good manifold.. :wink:
Or fit twin HS2s....
PostPosted: Thu Jun 30, 2005 9:27 pm
Why not? we are :wink: :lol:
PostPosted: Thu Jun 30, 2005 10:08 pm
The Cooper S crank in my 1360 is probably nearer 40 years old, it still gets spun to 7500.. :P
If it breaks, wot the hell- I've got a spare, and the 84.3mm stroker... :lol:
PostPosted: Thu Jun 30, 2005 10:26 pm
Dr thats twin 1 1/4 SU's hey do they give good power with a equaly matched cam grind?
PostPosted: Thu Jun 30, 2005 10:33 pm
All you need for a street 998, unless it's a racer.. then use twin HS4s! :wink:
Webers and Dellortos I like better for power, but they are noisy bastards, and you can't just stomp the throttle at idle like you can with SUs..
