https://ausmini.com/forums/
it this head dead?
https://ausmini.com/forums/viewtopic.php?f=5&t=82494
Author:  Wakes01 [ Sun Aug 25, 2013 7:07 pm ]
Post subject:  it this head dead?
Started stripping mt head down and noticed this is broken.
I think i know the answer but im guessing this is a doors stop?
Author:  Mick [ Sun Aug 25, 2013 7:25 pm ]
It is just the valve guide that is shattered. I'm not sure how it happened, but it can be easily pressed out with a new one pressed back in in a few minutes if the head is off.
Out of interest, how did you shatter it so badly? Where did the shattered bits end up, were they in the engine? :shock:
I turned the image right side up :) It was doing my neck in!
Author:  Wakes01 [ Sun Aug 25, 2013 7:27 pm ]
started removing the valves and after i bulled the sprint out i removed the rubber bit and this is what i was left with.
Its a motor i bought not running,
Author:  Mick [ Sun Aug 25, 2013 7:29 pm ]
No big drama then, just press the remainder of the guide through and replace it with a new one. it was work that would have been done perhaps anyway with a rebuild. Take a good hard look at the valve as well for wear.
Author:  drmini in aust [ Sun Aug 25, 2013 9:20 pm ]
I would look at the condition of all the guides, new standard ones are not expensive.
