It is currently Fri Jun 27, 2025 9:09 am
 Post subject: it this head dead?
PostPosted: Sun Aug 25, 2013 7:07 pm
Started stripping mt head down and noticed this is broken.
I think i know the answer but im guessing this is a doors stop?
PostPosted: Sun Aug 25, 2013 7:25 pm
It is just the valve guide that is shattered. I'm not sure how it happened, but it can be easily pressed out with a new one pressed back in in a few minutes if the head is off.
Out of interest, how did you shatter it so badly? Where did the shattered bits end up, were they in the engine? :shock:
I turned the image right side up :) It was doing my neck in!
PostPosted: Sun Aug 25, 2013 7:27 pm
started removing the valves and after i bulled the sprint out i removed the rubber bit and this is what i was left with.
Its a motor i bought not running,
PostPosted: Sun Aug 25, 2013 7:29 pm
No big drama then, just press the remainder of the guide through and replace it with a new one. it was work that would have been done perhaps anyway with a rebuild. Take a good hard look at the valve as well for wear.
PostPosted: Sun Aug 25, 2013 9:20 pm
I would look at the condition of all the guides, new standard ones are not expensive.
