Over bored 1275 https://ausmini.com/forums/viewtopic.php?f=5&t=82407 |
Author: | Minimad [ Thu Aug 15, 2013 8:35 pm ] |
Post subject: | Over bored 1275 |
Hi, I got given a 1275 (1100s) block that has been over bored to 72.8mm. Other than a boat anchor... what can I do with it?? ? Bigger bore?? ? Sleeve it?? ??? Or is it really throw away.... Thanks Minimad |
Author: | simon k [ Thu Aug 15, 2013 9:32 pm ] |
it's fine - 72.8mm is an odd size, but is .008" under 73mm which is a common size, making a 1360 oops, hang on.... it's a boat anchor, give me a few beers and I'll take it away for you ![]() |
Author: | drmini in aust [ Fri Aug 16, 2013 8:47 am ] |
You can go to 73.5mm (1380cc), [then 74mm (1400) if the block was offset bored]. Don't toss it yet... ![]() |
Author: | coopar [ Fri Aug 16, 2013 2:29 pm ] |
Do you have anything to go with it other than the block? I'm assuming you have other parts to build it up.. If not sell it. |
