It is currently Sat Jun 28, 2025 1:46 am
 Post subject: 998 +120 pistons
PostPosted: Tue Jul 23, 2013 3:09 pm
Hi All,
I'm from California and am restoring a Riley Elf Mk2 (from New Zealand). I want to keep the 998, but want as much "poke' as I can get.
Was wondering if anyone still has a set or 2 of the +120 flat top pistons? if not, where would the best place be to buy +100?
Oh, and for the rest of my motor:
12G295 Head (with unleaded seats)
Kent 276 or 266 (still to decide)
Weber 40DCOE
Megajolt for ignition (to tame the cam and Weber)
rods/crank/flywheel (slightly lightend) balanced but otherwise stock
Tranny: Stock ratios, 3.44 drive - might go to 3.1 if highway noise annoys me
Really hoping to keep up with the wifes Toyota Prius Hybrid :D
Thanks much for the help
Daniel
My Mini --> 1966 Riley Elf (currently in pieces!)
PostPosted: Tue Jul 23, 2013 3:27 pm
Hypatecs- http://www.minisport.com.au/prod1093.htm for +.100" flat tops.
Russell Engineering +.100" flat tops- http://www.minis.com.au/minis/catalog/p ... cts_id=660
+.120" seem scarce at the moment.
PostPosted: Tue Jul 23, 2013 4:03 pm
Put an 1100 crank in it.
PostPosted: Wed Jul 24, 2013 5:41 am
Thanks for the info Doc & AWoody
Not sure about going 1100 crank, they are a bit hard to find here...how much better is it for a street mini/commuter/weekend tracker over the 998?
Daniel
PostPosted: Wed Jul 24, 2013 8:54 am
more stroke,,,+,,, more capacity = more torque/power
PostPosted: Wed Jul 24, 2013 8:59 am
More driveable for a street car with a 1098 crank in, as you Yanks say `there ain't no replacement for displacement'.:mrgreen:
Gives 10% more torque to start with, even if motor is stock.
Its p/no is 12G82, if you are looking for one on the web. You would then need to buy 1098 pistons, not 998 ones (1098s have ~3.75mm less wrist pin height to crown). Conrods are the same, 998-1098.
PostPosted: Wed Jul 24, 2013 3:29 pm
pretty easy to find here - won't be hard to freight one
PostPosted: Wed Jul 24, 2013 3:50 pm
http://www.ausmini.com/forums/viewtopic.php?t=82192
:wink:
When buying one of these, try and get one that's still @ std size, or at -.010", and crack test it before buying.
