https://ausmini.com/forums/
Megajolt ignition engine mods?
https://ausmini.com/forums/viewtopic.php?f=5&t=81191
Author:  m1100s [ Mon Apr 22, 2013 8:18 pm ]
Post subject:  Megajolt ignition engine mods?
Just about to embark on a Megajolt project on my Morris 1100s, was just wondering if I need to remove the distributor drive shaft when I remove the dissy?. Also would it be practical to plug the hole with a correct size core plug?.
Regards,
Ash.
Author:  michaelb [ Mon Apr 22, 2013 8:55 pm ]
Yes you need to remove the distributor shaft plus plug up the hole
There are a few different plugs available, I think i got mine from an Ausmini member, Ben?
Here is the plug in situ
Author:  mini_mad_matt [ Mon Apr 22, 2013 8:55 pm ]
You can take the dizzy drive shaft out as it is no longer required. You can also put a plug in the hole.
There was a member on the forum who was making some aluminium covers, that bolt in place, but a welch plug still does the trick.
When i set my megajolt up i actually left the dizzy in place incase i had problems with megajolt, which i didn't, just to begin with.
Author:  simon k [ Mon Apr 22, 2013 8:59 pm ]
a 50 cent welsh plug works perfectly...
Author:  awdmoke [ Mon Apr 22, 2013 11:32 pm ]
You should not leave the dizzy driveshaft in without keeping the dizzy.
A Welsh plug will be fine.
Author:  mini13 [ Tue Apr 23, 2013 3:05 am ]
You MUST remove the dizzy drive,
it will lump out of its bearing in the block and get twatted bu the crank... not good!
Author:  m1100s [ Tue Apr 23, 2013 11:27 am ]
Thanks everyone, will make sure I remove it then. Anyone have a megajolt map for a supercharged 1275/1310 with about 12 psi ?
Ash.
Author:  michaelb [ Tue Apr 23, 2013 11:47 am ]
Maybe :wink:
But it could be very different to your requirements due to different engine builds?
If you PM me I can email you my latest map
Author:  benjamin [ Thu Apr 25, 2013 9:04 pm ]
hey , i make the billet ones if anyone is interested?
Made from 6061 billet, CNC machined to fit A-series engines.
Price is $40 each Machined Finish, includes new o-ring and stainless cap screw.
