For a start, do NOT use 10W-40 oil. Use 20W-50 for a standard Mini, and syntehetic is a big no-no. Castrol GTX2 (which is 20W-50) is a cheap oil that is good for a normal, not-heavily-modified Mini.
FWIW I picked up a 20W-50 today & put that in...it was basicly on the min mark prior to putting it in. I'll see how that goes.
LCB is not a brand. It stands for Long Centre Branch, and refers to the centre exhaust outlet pipe being longer than the ones on the side. The ones on the side join together, then lower down the centre one joins in as well, creating a 3-2-1 effect (and you'll hear people refer to them as these too). The old standard extractors were 3-1s, where the 3 pipes joined into 1 at a single intersection. These are narrow and are generally replaced with LCBs pretty quick smart.
Well I guess like any car the exhaust is the best place to start 1st with freeing things up. How easy or hard is it to fit these extractors?? I mean does the engine have to come out of dropped down on one side etc? can I do it in 2 stages? I mean will they match up with the OEM exhaust or is it better to just do it all in one go? And why would I get the LCB ones as a pose to getting an exhaust place to fab a full exhaust including extractors?? Any idea where in NZ I might get some (I'll do a search but if anyone knows)
A good air filter... K&N if you want to fork out the big bucks, but for what you have/want, get a Lynx pod filter for your size carby. As for determining the size of your carby, take off any air filter, and measure the diameter of the inlet.
Just a replacement in that round housing?? Will take it off and see what I can see
As for getting your hands on a 1275 and getting rid of the 998, it all depends on what you want from your Mini. I have a 1430cc (obviously a modified 1275), but the size of the bores mean that its not suitable for a turbo/supercharger due to the thin walls between cylinders (you COULD possibly run a really soft blower through it, but there isn't much point). I wasn't really interested in going through the mods needed to get a supercharger (custom manifolds etc.) so I'm sticking with the big cc's and Weber carby to get my real power (amongst other mods).
When it comes down to it, it's all a balance between time, money, patience, and personal opinion as to what you do with the engine that you have. Supercharged 850 (a member on this site) has a ripper small supercharged engine and shows what can be done with the lower end of the cc spectrum.
Well to be honest it's really just going to be for a run around & maybe a advertising vehicle so it needs to still be streetable. I can't really justify pouring heaps of $$ into it BUT as I mentioned offline to Volodkovich I wish it had better acceleration....and or the ability to surge foward a tad with the push of the accelerator. Going from my Turbo MR2 to the Mini is like night and day.....I will admit though it is indeed a fun car to drive and turns REALLY well....almost as good as my 2
KiwiMR2
