https://ausmini.com/forums/
Looking at putting a sc12 on a 1310
https://ausmini.com/forums/viewtopic.php?f=5&t=80333
Author:  mitchell evans [ Mon Feb 11, 2013 8:28 pm ]
Post subject:  Looking at putting a sc12 on a 1310
Hi my 1310 is need of a rebuild its getting bad oil pressure
would you supercharge it or not bother? 1310 with a webber goes quite well at the moment
are these sc12 supercharges reliable on the car?
so while its in pieces is these anything that I can put in the motor to make it stronger
Or just rebuild it as is
Its in a roundy van also
Thanks Mitch
Author:  Smarty [ Mon Feb 11, 2013 8:48 pm ]
Hi Mitchell
1310 with a supercharger :twisted: would be awesome, there is plenty you can do to make it go better and last longer!
This is the setup that I was going to run in my 850 so have all the info needed as far as building it up, it comes down to how much you want to spend on the rebuild.....
However you can just do a 'std' rebuild (allowing for correct compression ratio for supercharger) and pop the supercharger kit on top of the engine so to speak.
or you can go all out with
wedged or forged crank
h beam rods
race pistons and rings
steel main caps
lightened flywheel and backplate
ported head
big valves
1.5 rockers
RE13T cam
Straight cut box
Straight cut drops
LSD
etc
again just depends on budget and how much power you want Vs reliability.
I am sure you will get plenty of comments about it on here. :D
Author:  simon k [ Mon Feb 11, 2013 9:30 pm ]
Post subject:  Re: Looking at putting a sc12 on a 1310
Not as well as it would with a blower on it. It's a 40% more power at the wheels "bolt on" - that's what mine went from on the dyno - a bit over 60hp atw to a bit under 90
Depends what you mean by reliable and depends on what you do with it - there will be teething issues, but reliability doesn't take a huge hit.
I am about to rebuild mine after 25,000ks of daily driving and doing a motorkhana once a month...
Author:  mitchell evans [ Mon Feb 11, 2013 10:03 pm ]
Thanks for the help just what I've been looking for
also do they fit under the bonnet without tilting it?
Author:  mini_mad_matt [ Mon Feb 11, 2013 11:06 pm ]
Yep they fit nicely
A user on here '92' makes all you need to fit the sc12 if you don't want to try and make your own kit. It's well made and a proven product.
You still need your own carby etc though.
Author:  mitchell evans [ Tue Feb 12, 2013 12:10 am ]
How do I get in touch with him
What carb do I use to
Author:  Smarty [ Tue Feb 12, 2013 8:53 am ]
The best carb is a Hif 44.
Author:  mini_mad_matt [ Tue Feb 12, 2013 6:02 pm ]
Send him a private message through the forum.
His username is simply 92
Author:  PetenSoaf [ Tue Feb 12, 2013 8:50 pm ]
There's two or three cars in the SDMC with SC12's fitted Mitchell. . .Adrian Vernon has one on his car (1275 round nose), Kim Barnard has one on her Clubby van (1330, I think) and I have one on my Moke (bog stock 998).
I'm sure any of them/us would be happy for you to have a look if you want to see how it's all set up before you go ahead. . .
Author:  Super-mini [ Mon Feb 25, 2013 5:12 pm ]
must haves are
turbo main bearings
extra head studs
8to1 compression
uprated clutch
uprated radiator
turbo head gasket
Author:  PetenSoaf [ Mon Feb 25, 2013 6:20 pm ]
I'd agree on the clutch but as for the rest of it, I'd say the most important 'must haves' are correct fuelling and limiting total ignition advance.
The 998 in my Moke is completely standard apart from a set of extractors and a Pertronix igniter and I've been hammering it fairly hard with a SC12 for almost 5 years now. It still has 75psi running oil pressure and 140psi compression in each cylinder.
Maybe I've just been lucky though. . .
