Pick my Parts https://ausmini.com/forums/viewtopic.php?f=5&t=80282 |
Author: | davem [ Thu Feb 07, 2013 3:56 pm ] |
Post subject: | Pick my Parts |
Hey guys Managed to have my first mini written off, saved the boot lid and the motor/gearbox! to get the motor running again l need to replace the following:- Dizzy,coil,radiator,oil cooler,alternator, manifold. Ive got a budget of 4k for parts and would like to do some upgrades as my new mini is bog stock, still has the dealer stickers on it. Below is what l am proposing on buying from uk minispares, l am asking members to advise/recommend alternates if im heading down the wrong track. Current Motor Specs 1310cc Morris 1100s motor 12.1 comp straight cut gears Torana LSD mild cam port and polish Cooper S Calipers Brass button Clutch 45 Webber Here is my shopping list Bilstein Shocks Hi Lows Maniflow Manifold http://www.minispares.com/product/Class ... .aspx|Back to shop Maniflow Exhaust http://www.minispares.com/product/Class ... .aspx|Back to shop Alternator http://www.minispares.com/product/Class ... .aspx|Back to shop Lucas Sports Coil Radiator http://www.minispares.com/product/Class ... .aspx|Back to shop Oil Cooler http://www.minispares.com/product/Class ... .aspx|Back to shop Braided Brake Lines http://www.minispares.com/product/Class ... .aspx|Back to shop Lightned Flywheel http://www.minispares.com/product/classic/C-AEG421.aspx Brake and Clutch Master Cylinders (ap minispares) 1.5 Roller Rockers http://www.minispares.com/product/Class ... .aspx|Back to shop or http://www.minispares.com/product/Class ... .aspx|Back to shop Geometry Kit http://www.minispares.com/product/Class ... .aspx|Back to shop Anti Roll Bars http://www.minispares.com/product/Class ... .aspx|Back to shop http://www.minispares.com/product/Class ... .aspx|Back to shop Thanks for all advice Regards Dave |
Author: | Lillee [ Thu Feb 07, 2013 4:02 pm ] |
Hey Dave, Skip the full roller rockers and get the roller tip. The reason for this is that a bushed rocker has more contact area than a roller rocker does, which has all of the forces pushed against a couple or needles inside the roller bearing (no good). Have you considered these instead? I am considering the LD rockers... http://www.med-engineering.co.uk/catalo ... rocker-set LD Version: http://www.med-engineering.co.uk/catalo ... ld-rockers I'd skip the oil cooler, no need for one. Have never run one in my car, unless you plan to race and are monitoring oil temps and the situation calls for one. |
Author: | Bubbacluby [ Thu Feb 07, 2013 4:05 pm ] |
Sorry.... I say if its bog stock with dealer stickers. Leave it and Love it. Keep it bog-stock. will retain its value much better in my opinion |
Author: | davem [ Thu Feb 07, 2013 4:34 pm ] |
Bubbacluby wrote: Sorry....
I say if its bog stock with dealer stickers. Leave it and Love it. Keep it bog-stock. will retain its value much better in my opinion I will be keeping the exterior and interior original just want some more out of the motor. I believe my car still has a delivery number on the front windscreen, chrome roof racks and a sun visor |
Author: | davem [ Thu Feb 07, 2013 4:47 pm ] |
[quote="Lillee"]Hey Dave, Skip the full roller rockers and get the roller tip. The reason for this is that a bushed rocker has more contact area than a roller rocker does, which has all of the forces pushed against a couple or needles inside the roller bearing (no good). Have you considered these instead? I am considering the LD rockers... http://www.med-engineering.co.uk/catalo ... rocker-set LD Version: http://www.med-engineering.co.uk/catalo ... ld-rockers Thanks mate will consider med just don't want to get stung multiple times on postage. Whats the advantage of the ld version? Was only going to run a cooler as it previously had one |
Author: | Lillee [ Thu Feb 07, 2013 6:50 pm ] |
Not much difference for a road car, but I figure for $100 more you I might as well since it's already $340 right? ![]() |
Author: | mickmini [ Thu Feb 07, 2013 9:12 pm ] |
I got the LD ones. They look good, but i am yet to run them.Will post results once i have. cheers michael |
Author: | davem [ Fri Feb 08, 2013 2:22 am ] |
mickmini wrote: I got the LD ones. They look good, but i am yet to run them.Will post results once i have.
cheers michael Hey mate what was postage roughly? Had a look at there flywheels but confused what type do l need verto/ pre-verto???. They also mention pre a+ plus or a+plus when selecting parts what's the difference? |
