It is currently Fri Jun 27, 2025 7:48 am
 Post subject: The right fuel
PostPosted: Wed Feb 06, 2013 3:25 pm
Many years back when i bought my race mini I didnt ask a lot of questions, I just paid way too much for it but smiled ear to ear for a long time afterwards. I did remember one thing and that was that the guy told me to only run av gas so that is what I did.
Now that I am building my own race/fast road mini I want to know everything so I do it right
So about fuel - Im assuming that running av gas gives you a slight advantage over PULP? what do you have to do to your engine to be able to safely run it? is it worth it?
cheers in advance
PostPosted: Wed Feb 06, 2013 4:43 pm
AVGAS has a gigher octane rating, and it still contains lead so you don't need hardened inserts or valve saver.
You really need a high compression motor to take full advantage of running AVGAS.
PostPosted: Wed Feb 06, 2013 6:02 pm
Much of the avgas sold now is low in lead, and only about 100 octane. The good old days of aircraft rocket fuel are going.
:cry:
PostPosted: Wed Feb 06, 2013 6:16 pm
:cry:
There is a big difference between "Low Lead" and "low in lead"
The most commonly used aviation fuel is 100LL, that is, "low lead". It is dyed blue and contains a relatively small amount of tetraethyllead—though the amount is greater than what was contained in many automotive grades of leaded fuel before such fuel was phased out.
This fuel still has more lead than the old Super but not the same amount of lead as 100/130 which would often cause plugs to foul with lead deposits.
PostPosted: Wed Feb 06, 2013 7:02 pm
and because it contains lead (and lacks the tax that road fuel attracts) is illegal for road use.
you can smell the difference from the exhaust.
PostPosted: Wed Feb 06, 2013 7:49 pm
I think it's a different colour, too.
Get caught using it on the road in NSW and it's tata to $5K, I think.
I'll stick to my BP or 7/11 premium 98 + Flashlube, works for me.
PostPosted: Mon Apr 08, 2013 12:04 am
In SA as well ,plus using it on the race track... Mallala, will incur a fine from the Stewards/Cams.
see last line in my signature below :lol:
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Mon Apr 08, 2013 7:55 am
Theres no need to change jetting from pump fuel to av-gas, it`s just petrol just like any normal petrol,,, just that it can handle higher compression ratios (higher octane rating & a lot cleaner) than std-ish pump fuels
it`s not allowed on the road
but it`s absolutely & totally allowed at all the race tracks everywhere that i know of...
Mallala must be the only race track that it`s not allowed, are you sure you`re not talking about methanol DA9jeff
PostPosted: Mon Apr 08, 2013 11:50 am
Cannot use Avgas at Mallala?
I thought this was the predominant fuel used in Historic racing?
PostPosted: Mon Apr 08, 2013 11:53 am
last time a cop ask me if i was running av gas i told him it was caster oil , got away with that one
PostPosted: Mon Apr 08, 2013 11:58 am
never checked the whats under the cap lol
PostPosted: Mon Apr 08, 2013 7:30 pm
yeh, Historics only.... see Sec 8.4.6 Schedule G in the Cams Manual
Need Cams authority to use any Leaded fuel as well.
CAMS Scrutineer
PostPosted: Mon Apr 08, 2013 8:58 pm
Oh dear, worry, worry...
HI Matt
AV Gas is not allowed to be used ?/sold at any race track because of the tax it incurs thats why they call it shell 100 racing fuel same fuel different name,its the word av gas they can not use.
Graham Russell
PostPosted: Mon Apr 08, 2013 9:37 pm
Ok so i'm reading this section now, and i'm not seeing what 8.4.6 has to do with being allowed to use avgas.
So we are in schedule G - Fuel
To define avgas....
8.3 - Racing fuel
8.3.1 - Leaded Racing Fuel: Leaded racing fuel is defined as a leaded petrol which is supplied by an oil company and having a composition the same as that supplied for piston engine general aviation use, ie, AvGas 100/130 or AvGas 100LL only.
Now lets move to section 8 - Fuels Regulation committee
8.4 - Restrictions: The committee will consider requests for restrictions to:
8.4.6 - Racing Fuel: Where a restriction to racing fuel is sought, an additional restriction to unleaded racing fuel may also be approved. In general, restrictions to leaded racing fuel only will not be authorised for other than competition solely for 5th Category automobiles (historics).
So to me, 8.4.6 means that you can apply to HAVE a restriction on the use of race fuels. AND restrictions to use ONLY leaded fuel will not be authorised UNLESS it is for competition for 5th category.
So to me that's saying that you could apply to make everyone run on avgas in a historic competition. No where does that read to me that you can't use avgas, unless specified in the event regulations.
I would like to hear your understanding of that rule though, as i am only reading it out of a book and i may be misreading
PostPosted: Tue Apr 09, 2013 8:46 am
GR wrote:
HI Matt
Graham Russell
hee hee
rules & all their various interpretations hey? :-)
back when i was racing the short-circuit dirt track scene at Echo Valley Toowoomba they tricked me at one of the meetings by having 5 races instead of the usual 3 races,,, so of course i was obviously going to run out of fuel later in the day
so,,, when this EH holden rolled over i waited till the end of the next race to ask him (just so i didn`t look too much like a vulture) but seeing as he obviously wasn`t going to be racing any more of this day i asked him if he had any spare fuel that i could buy off him
well,,, he looked around all suspicious like & reached around the back of his truck & grabbed out this 20litre drum & started shaking it & saying mate you`ll have to mix it good before you pour it in your tank,,, (still looking around all suspicious like) so i asked what it was??? he said a mix of 1/3av-gas, 1/3 toluene & 1/3methanol & "u could probably do with going up in jet sizes a fair bit" he said,,, & then he leaned towards me & wispered "But don`t tell anyone ok?" & winked at me... :-)
so,,, i knew i was already running a bit rich so i didn`t bother mucking with anything,,, paid him the money & poured that-stuff in my car... well what else was i goiung to do i didn`t have any fuel left & as far as i knew you can`t race a race without petrol right??? :-)
welllllll...... from starting at the back of the grid (28 cars) in all the earlier races we caught up to first place & was overtaking him at about lap 12 or 14 ish (nearing the end of the race),,, but once we poured "that-stuff" in for the last couple of races we were overtaking first place at about 8 laps into it & just absolutely flying away from everyone!!!!
whatever it was it really liked my engine & state of tune.
My girl Marly was in the car ,,, she can tell you ,,, the difference was amazing & back then i was normally using the good mobil 100-130,,, so "that-stuff" was some pretty nastey stuff i can tell you :-) i never bothered to mix up my own batch but since then i`d heard of plenty of people doing the same-ish thing just making sure that they had "run-out of fuel" at the end of the race so there was no fuel left to test :-) funny that hey? :-)
