It is currently Fri Jun 27, 2025 11:10 pm
 Post subject: Megajolt & Sidedrafts
PostPosted: Mon Dec 17, 2012 3:48 pm
So I'm in the process of planning my engine build out and have decided to go with a megajolt rather than a dissy. Does anyone here have any experience with megajolt and a sidedraft carb?
I've got a non-emissions dellorto 40 I want to use on what I plan to be a bored out 1100. I've read that using a throttle postion sensor on a side draft is preferable to using a MAP setup, does anyone have any thoughts on this, or experiences?
Nick
Basil - 1978 Leyland Mini, Brooklands Green, bit of a bitsa, and a park brick in the boot. :)
PostPosted: Sun Dec 30, 2012 9:06 pm
I believe throttle position sensor would be best. I'm tackling a Megajolt install on my alfa (twin dellortos) this year so I'm faced with the same problem. I will be going for throttle position sensor if I can sort out the mounting and wiring. I've also seen quad throttle bodies using one map sensor drawing vacuum from the intake manifold using an oversized vacuum line like a fuel rail but big enough to smooth out the vacuum pulses. To be honest I still haven't decided which I will go with, but I hope in all this there is something of use to you.
Lindsay Palmer
06 Mazda SP23
80 Alfa GTV (weekend toy)
86 626 Turbo (daily drive, now stolen)
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
Users browsing this forum: No registered users and 23 guests
