It is currently Fri Jun 27, 2025 12:37 am
PostPosted: Wed Jan 02, 2013 4:45 pm
Hi everyone. I have a friend who has offered to sell me his newly machined thick ended 850 crank he no longer needs. My question is, will this fit into the block of an 850 that originally had a narrow ended crankshaft or would machining be required? I guess a few parts would need to be swapped such as flywheel etc.
thanks
Present
'71&'76 Clubman minis
1961 Austin Se7en
PostPosted: Wed Jan 02, 2013 6:28 pm
It drops straight in. You then use the same flywheel and primary gear as a 998/1098, not the old 850 ones (which are both too small in the bore).
PostPosted: Wed Jan 02, 2013 6:49 pm
OK great! thanks for that DrMini! Is there an oil hole i need to plug up on the block?
Present
1961 Austin Se7en
PostPosted: Wed Jan 02, 2013 7:58 pm
You are thinking of the old wet tail crank's lube hole for the primary gear bush?
Nope, the thick tail 850 crank came out when they went to dry primary gear bushes. it's exact same tail as a 998 or 1098.
PostPosted: Wed Jan 02, 2013 9:22 pm
ah yes. good point i was getting myself confused. thanks for that. I will let you know how it comes along. I probably wont start working on it for some time yet.
Present
1961 Austin Se7en
PostPosted: Wed Jan 02, 2013 9:24 pm
Present
1961 Austin Se7en
Users browsing this forum: No registered users and 25 guests
