My idea was to use it as a base then modify the runners to reduce down to the BMW port and a custom made IM port face.
The idea was to save a bit of time making the whole thing seeing as this is already made, runners just needs to be cut to length and or the mounting face made to reduce the ports down to the BMW size. like a funnel not just a plate welded to the end of the Magna ports, that's just a terrible design.
It would use the std Magna TB IM and the throttle cable bolts to the IM so simply shorten the other end to connect to the mini pedal, it's a decent design and IMO only needs some basic mods to be usable on a single carby, forced induction or with a correctly moded mounting face you could use the std BMW injectors and EFI it. The std size of it lends itself more to a Clubman but could be shortened to fit in a roundnose engine bay.
This is what I have made so far for my own setup;
For now I'll stick with my own creation but it still need a heap of work and has taken a fair bit of time just to get where I am now.
