What plugs for pulsar dizzy https://ausmini.com/forums/viewtopic.php?f=5&t=7862 |
Author: | 72clubman [ Mon Jun 06, 2005 2:15 pm ] |
Post subject: | What plugs for pulsar dizzy |
As the topic says what are the best sort of plugs and gaps to run when you have a pulsar dizzy installed, or should you use the ones reccomended for a nissan pulsar |
Author: | Damo [ Mon Jun 06, 2005 2:24 pm ] |
Somewhere in the original thread it stated: "Plugs: NGK BP6ES, Bosch W6DC are also good. Plug gaps- .040" fires OK with the stock Nissan 1.5 ohm coil to 8000 rpm" I just reset my current plugs to a 0.035" gap for the time being, with no problems. I will change to the NGK BP6ES with a 0.040" gap next service and give it a try. |
Author: | drmini in aust [ Mon Jun 06, 2005 5:19 pm ] |
Plugs are always chosen based on the motor, NOT the dizzy.. Whatever plugs you have running now will still be fine. Open 'em up a bit as said. If you get any misfiring, close them back up a bit. .035"- .040" usually OK. ![]() |
Author: | Besser [ Tue Jun 07, 2005 7:38 pm ] |
Post subject: | gap setting |
Read an indepth article on plug gap and the outcome was 0.8mm. Forced induction or NA hot or std all came back to best overall performance from 0.8mm. I did find interesting the note regarding spark energy and duration. Seems that atomisation and turbulance was the gremlin for plug deterioration. hmm go figure |
Author: | 72clubman [ Wed Jun 08, 2005 10:12 am ] |
What is a plug gap of 035"- .040" in mm |
Author: | rampage101 [ Wed Jun 08, 2005 12:08 pm ] |
Nope, the " stands for imperial measurment of inches, also ' stands for feet. Edit: Ie. 0.040" is 0.040 inches. Ie. 3' is 3 feet. |
Author: | Damo [ Wed Jun 08, 2005 1:23 pm ] |
72clubman wrote: What is a plug gap of 035"- .040" in mm
0.8mm (divide by 25.4 mm to the inch) = approx. 0.032" |
Author: | drmini in aust [ Wed Jun 08, 2005 5:48 pm ] |
Damo wrote: 72clubman wrote: What is a plug gap of 035"- .040" in mm 0.8mm (divide by 25.4 mm to the inch) = approx. 0.032" Or remember that 1.0mm = .040" near enough- (actually 0.03937") ![]() |
