Rust-replacement floorpan https://ausmini.com/forums/viewtopic.php?f=5&t=7779 |
Author: | Flying Brick [ Fri Jun 03, 2005 12:18 pm ] |
Post subject: | Rust-replacement floorpan |
Im sure someone here has replaced a floorpan in a mini before, I am just wondering if you can get them for a mini with fluid suspension, they have the channel down the middle and an extra rib. I have bought one for my 850 and it fits(no channel in 850), all the ones i have seen on ebay and the one i bought dont have the channel. If you cant get one for the hydro setup, is it possible to put the other one in. The ribs dont line up. I have 4 minis and 3 have the drivers floorpan cut out ready to replace. Steve. |
Author: | rampage101 [ Fri Jun 03, 2005 12:55 pm ] |
Afaik you can't get them anymore in Aus. Please correct me if I'm wrong. |
Author: | drmini in aust [ Fri Jun 03, 2005 2:21 pm ] |
All the ones I've seen here are UK made, with no pipe channels as they didn't have them over there. Also, they are a bit thinner than ours- when I did Anton's 850 the original floor was 1.6mm, the UK front pans I bought were 1.0mm. Yes the ribs don't line up properly, even on the 850 shell. ![]() |
Author: | MiniK [ Fri Jun 03, 2005 4:23 pm ] |
Same problem here and its a pain in this ass ![]() |
Author: | 9YaTaH [ Fri Jun 03, 2005 4:33 pm ] |
Post subject: | Re: Rust-replacement floorpan |
Flying Brick wrote: Im sure someone here has replaced a floorpan in a mini before, I am just wondering if you can get them for a mini with fluid suspension, they have the channel down the middle and an extra rib. I have bought one for my 850 and it fits(no channel in 850), all the ones i have seen on ebay and the one i bought dont have the channel. If you cant get one for the hydro setup, is it possible to put the other one in. The ribs dont line up.
I have 4 minis and 3 have the drivers floorpan cut out ready to replace. Steve. Steve...a car has just been cut up in Canberra for just that reason...looks like you need to find a donor shell (or three)... ![]() |
Author: | drmini in aust [ Fri Jun 03, 2005 5:08 pm ] |
You could replace all 4 pans, or get a whole floor? then clip the pipes and stuff on like early Mini Deluxe and Cooper S had. No channels in floor. ![]() |
Author: | justminis [ Fri Jun 03, 2005 8:38 pm ] |
I had to replace both front floors on my 70 K sprint mini, used the ready available floor pans and had my friendly sheetmetal guy bend up some channels that I then inserted in the appropriate place in the floor. A bit of work but it worked. Stiffened up the floor too. |
Author: | Flying Brick [ Mon Jun 06, 2005 8:30 am ] |
Thanks for all the replys and ideas, i havnt had the net for the weekend so i have only seen them now. I guess i will try and find a shell to cut up, or maybe i will put the replacement panel in and just have them going along touching the panel, they have the cover over them so they should be ok. Thanks again. Steve. |
Author: | rampage101 [ Mon Jun 06, 2005 10:39 am ] |
Well while were on the subject, does anywhere in Aus sell complete floor pans as opposed to 4x floor pan sections?? |
