https://ausmini.com/forums/
Rev Limiter
https://ausmini.com/forums/viewtopic.php?f=5&t=7762
Page 1 of 2
Author:  Anto [ Thu Jun 02, 2005 6:49 pm ]
Post subject:  Rev Limiter
Has anybody here tried fitting a rev limiter to their car? I'd be interested in fitting one to mine, I've had sticking throttles in the past and I don't want to damage my engine if it happens again.
I googled and found that Pertronix do one, but its a bit pricey - I would have though this would be the sort of item you'd find at SuperCheap?
Author:  Spaceboy [ Thu Jun 02, 2005 8:44 pm ]
isnt it that the valve bouncing stops the engine from reaching terminal velocity
Author:  scotty [ Thu Jun 02, 2005 9:00 pm ]
piston thru block leaving big dent/hole in bonnet = rev limit reached :D
Author:  TheMiniMan [ Sat Jun 04, 2005 10:48 am ]
Volkswagen Kombies have a rotor button with a spring loaded earth tab fitted,,,exccellent rev limiter & easy to fit to the Aust 29D mini distributor,,,easy-est & cheapest & most effective rev limiter ever made...piece of P!$$
I know everything don`t i ??? :-)
ok,,,maybe not everything :-)
Author:  Chris [ Sat Jun 04, 2005 11:37 am ]
Here you go
http://www1.jaycar.com.au/productView.a ... &SUBCATID=
Author:  drmini in aust [ Sat Jun 04, 2005 10:21 pm ]
OT....
Obviously they didn't all get that, most 1500 Kombis had a vacuum governor..
I once worked on one which had it missing- and the owner had had the gearshift apart & f***ed it up and only had 1st & 2nd gear... he tried to drive it 30 miles to our workshop to fix, the motor over-revved, seized a piston & welded #3 rod to the crank. Nasty....!
But we fixed it. 8)
Author:  Anto [ Sun Jun 05, 2005 3:58 pm ]
He he that sounds simple enough to work... now how do I set the rpm it works at? Would be really annoying if it cut the rpm at 4000 :)
Author:  willy [ Wed Jul 13, 2005 4:34 pm ]
http://www.proquip.com.au/ftdrl.html
Yum.!
More things to save for 8)
Author:  Metalfab_101 [ Wed Jul 13, 2005 6:41 pm ]
You forgot to say "easy peasy" :P
Just throwing another idea out there, you could control your ignition with a Megasquirt. You could rev limit with spark cut and have a fully programmable ignition map to boot. Though i'd say it would probably be the most difficult and time consuming way of doing it. Funnily enough I always seem to do things the most difficult and time consuming way :lol: :oops:
Author:  Mini Mad [ Thu Jul 14, 2005 4:37 am ]
Yum.!
Ooooh..that's nice..
Author:  willy [ Thu Jul 14, 2005 11:23 am ]
Its pretty expensive though.
But saves your engine... blah blah blah :roll: :)
The write-up always makes them sound good, and try to get you to spend money. I think its working. :x :lol:
Author:  cush [ Thu Jul 14, 2005 1:17 pm ]
OMEX (in engerland) have a model funnily enough called the clubman and it's ~$200
http://www.omextechnology.co.uk/page4.html
Author:  willy [ Thu Jul 14, 2005 4:54 pm ]
Yeah that looks cool... but if i were to get one i'd like to match things.
Pertronix ignition with Pertronix rev limiter.
Sounds cooler than
Pertronix ignition with Omex rev limiter :roll: :lol:
Author:  cush [ Fri Jul 15, 2005 11:14 am ]
so a clubman with a omex Clubman doesn't suit?
edit... the new signature's slick but aren't you getting a bit ahead of yourself?
Author:  drmini in aust [ Fri Jul 15, 2005 11:20 am ]
Rev limiter, pffft.. build it right & it won't matter! :lol: :wink:
