It is currently Sat Jun 21, 2025 3:29 am
 Post subject: Wiring A Smiths Tacho
PostPosted: Sat Jun 05, 2004 2:25 pm
Hi,
I'm just fitting a Smiths tacho that I got hold of but its not working.
It's one of the current sensing type I believe -
It's a 4/6/8 cylinder gauge and I've got it set to 4 cyl ;-)
It has three spade connectors marked the following:
Red - Positive
Black - Negative
Blue - Sensor
Red - Fuse connector 4. I want it to get power when the key is 'on'
Black - I've crossed over and am using the earth from my temperature sensor guage.
Blue - I have connected to the Negative side of the Coil. This is the side that goes into the dizzy. My car is negative earth.
It also has a spot for a bulb to plug in, which I haven't done yet & two posts for mounting. I'm not grounding the casing at all.
Any suggestions?
dewey
dwightgunning.com
PostPosted: Sun Jun 06, 2004 12:06 am
dewey wrote:
Hi,
Red - Positive
Black - Negative
Blue - Sensor
Any suggestions?
dewey
dewey, in the olden days, the "sensor" was an extended low tension wire looped around a purpose built terminal block on the back of the instrument....however, yours sounds more modern :roll:
PostPosted: Sun Jun 06, 2004 10:55 am
Its an old school one. It's one of the Current Sensing types 'RVC' is the model prefix.
If nobody can see anything obviously wrong with the way I've wired it I'll start checking the connections and then assume that its dead. I might look at having it fixed cause I like the old style look.
dewey
dwightgunning.com
