Camira Brakes https://ausmini.com/forums/viewtopic.php?f=5&t=7722 |
Page 1 of 2 |
Author: | Konzo [ Tue May 31, 2005 11:29 pm ] |
Post subject: | Camira Brakes |
Hey, If i wanted to do a disk brake conversion for my mini and someone was chopping a camira, what parts from the car do i require for the conversion? Lucas |
Author: | nuclear_mini [ Wed Jun 01, 2005 11:18 am ] |
you need the rotors and calipers.... |
Author: | Konzo [ Wed Jul 06, 2005 10:52 pm ] |
Okay so if I can get my hands on a set of calipers and rotors ... and i have a standard clubman with drum brakes, what other items do I need? Or can i just bolt the camira calipers and rotors on? |
Author: | Konzo [ Thu Jul 07, 2005 3:19 pm ] |
Anyone? |
Author: | BLACKRZ_667 [ Thu Aug 04, 2005 5:59 pm ] |
ANYONE? |
Author: | 13secmini [ Thu Aug 04, 2005 6:58 pm ] |
you will need a bracket made up to bolt to the hub, then the caliper bolts to this. not sure what else is needed. |
Author: | drmini in aust [ Thu Aug 04, 2005 7:16 pm ] |
nuclear_mini's mate does a kit for this- all you need is the kit, + the Camira rotors & calipers. ![]() |
Author: | red078 [ Thu Aug 04, 2005 7:27 pm ] |
Does anyone know how much the kit costs?, and if you can use 12 inch wheels?, thanks Tony ![]() |
Author: | drmini in aust [ Thu Aug 04, 2005 7:33 pm ] |
red078 wrote: Does anyone know how much the kit costs?, and if you can use 12 inch wheels?, thanks Tony
![]() I think the kit was 200 odd bux. Plates etc were laser cut. I forgot to add you also need S C/Vs and drive flanges, for the kit I saw. nuke mini had them inside 12" wheels. Whether legal or not, I dunno, but they sure looked sweet. |
Author: | Spaceboy [ Fri Aug 05, 2005 12:23 am ] |
sounds good but how much is it for S type cv's and flanges and are they easy to swap over? |
Author: | drmini in aust [ Fri Aug 05, 2005 7:01 am ] |
S C/Vs are on cheap at the moment from MiniSport in Adelaide, $65 ea I think. So Chong said... ![]() S drive flanges list in Sydney at $93.21 ea, I'd try MiniSport for those too. You need to pull the whole hub off, and driveshaft out, swap C/V on shaft, refit. I'd change the wheel bearings while you're in there, & fit Timken tapered roller kits. Hell, you might as well clean all the hub up and paint it too.... |
Author: | harvey69 [ Mon Mar 26, 2007 2:39 pm ] |
THREAD REVIVAL.... Is this nuclear_mini's still around...? ? ? interested in this kit his mate makes....? ? |
Author: | Mini Mad [ Mon Mar 26, 2007 2:56 pm ] |
he's dropped off the face of the earth...and has taken off with some members stuff he 'borrowed' while he was at it too ![]() |
Author: | willy [ Mon Mar 26, 2007 3:37 pm ] |
We'll find him. The mini scene isn't that big in Australia.. ![]() |
Author: | slinkey inc [ Mon Mar 26, 2007 5:02 pm ] |
True, but Australia is pretty big. |
