Simon,
A Cooper S crank WILL go into an 1100S block, my 1360 runs one.
You just surface grind ~.016" off the steel backing of the standard thrusts..
Yes as I told you before, if you put an 1100S crank in an S block you use +.030" thrusts and surface grind their steel backing to suit.
You want at least .006" end float if it's getting a rev, .003" in the book is
not enough. I found out the hard way...
Kirby, re the rods, small journal 1100S and Cooper S (most 1275) ones are the same. AEG521.
If running a big journal 1275 crank (unstroked) you want late 1100S rods, or A+ rods (lighter & better).
Stroking the big journal 1275 cranks by ~3mm is popular, it's an easy way to pick up ~50 extra cc and more torque. You then need Cooper S rods (narrowed in width by 1/32" approx).
I'm building one at the moment...
Of couse if you have the do$h, you could buy aftermarket competition rods but IMO they are bit overkill for street use.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
