It is currently Fri Jun 27, 2025 1:57 pm
 Post subject: MG Metro conrods
PostPosted: Tue Apr 24, 2012 12:01 pm
Can anyone give me the specs on a 1275 MG Metro con rod big end, small end, and length C-C?
PostPosted: Tue Apr 24, 2012 6:15 pm
Hi,
sizes are the same as a normal and heavy 1275 ( non S ) rod .
Big End 1.8955"
Small End/pin bore: 0,8125"
center to center : 5.75"
Hope this helps.
Luis
 Post subject: cool
PostPosted: Tue Apr 24, 2012 10:24 pm
Thanks I'm getting some made and wanted to confirm specs.
 Post subject: Re: cool
PostPosted: Thu Apr 26, 2012 2:25 pm
Mods rock!
You'll also need the off-set.
PostPosted: Thu Apr 26, 2012 5:03 pm
It would be a bugger of an Oops moment if the offset was forgotten! Good point GT.
