fuzzy-hair-man wrote:
To get the option of front, rear, or all wheel drive (without taking out drive shafts) doesn't this mean you will need four diffs?
1 for front wheels, 1 for rear wheels, one to stop/go drive to rear wheels one to stop/go drive to the front wheels.
I was thinking of a clutch pack type diff you would have to take these appart to change the torque split.
How are you going to work it? I mean your rear wheels have to be able to spin some amount slower that the front wheels so you don't get problems going round corners right?
The last page of this article has some links that might let you know what is available.
http://auto.howstuffworks.com/differential11.htmHope it helps
Bye Arrin
I do kinda need 4 diffs, 2 of them are real diffs, and 2 switchable couplings. The existing viscous coupling gets over the problem of the rear wheels spinning slower than the fronts when going around corners - it always has a degree of slip in it. Hopefully whatever coupling I can find will be able to have a little slip in it, or maybe set it at 30% of the power when on tarmac, and 50% when on dirt
The problem with the existing viscous coupling is that it's only working when the rear wheels are going a different speed to the front wheels (more than just the speed difference when turning), so it is fairly slow to react, basically only working when you're already in trouble. I'm looking to replace that with something more 'proactive', as in "I'm about to do something where I want 4wd", instead of "I'm doing something where 4wd might be a good idea.... oh, now would be a good time..... any time soon would be nice....."
The awd gear I have has a driveshaft length equaliser shaft across the back of the motor, which I reckon is perfect for fitting another switchable coupling in-line. If I was to turn that coupling off, all the drive from the front diff would go to the inboard side of that coupling (as it's the easiest path), so none of the drive would go to the front wheels at all
did I tell you that I won a
trophy?
