https://ausmini.com/forums/
Setting the cam timing for a RE13
https://ausmini.com/forums/viewtopic.php?f=5&t=75570
Author:  mini bug [ Sun Feb 19, 2012 9:45 am ]
Post subject:  Setting the cam timing for a RE13
What would be the degrees after TDC to set it up a RE13 cam?
Author:  simon k [ Sun Feb 19, 2012 10:03 am ]
GR usually engraves it on the end - mine is 105.5
Author:  Mini68 [ Sun Feb 19, 2012 1:35 pm ]
http://www.ausmini.com/forums/viewtopic ... highlight=
Author:  mini bug [ Tue Feb 21, 2012 5:28 pm ]
Great
Thanks for the info !
Author:  drmini in aust [ Wed Feb 22, 2012 8:27 pm ]
Lately he engraves it on the cam body.
That number is actually the LCA that he's ground the cam to, it just so happens if you dial the cam in `straight up' as they say, it is the max intake lobe lift point ATDC.
[edit] LCA = Lobe Centreline Angle, = measured angle between the intake and exhaust lobes on the cam.
