It is currently Fri Jun 27, 2025 8:27 pm
PostPosted: Sun Feb 19, 2012 9:45 am
What would be the degrees after TDC to set it up a RE13 cam?
Just cause it says it is for a mini ,doesn't mean it will fit a mini......
PostPosted: Sun Feb 19, 2012 10:03 am
GR usually engraves it on the end - mine is 105.5
PostPosted: Sun Feb 19, 2012 1:35 pm
http://www.ausmini.com/forums/viewtopic ... highlight=
PostPosted: Tue Feb 21, 2012 5:28 pm
Great
Thanks for the info !
PostPosted: Wed Feb 22, 2012 8:27 pm
Lately he engraves it on the cam body.
That number is actually the LCA that he's ground the cam to, it just so happens if you dial the cam in `straight up' as they say, it is the max intake lobe lift point ATDC.
[edit] LCA = Lobe Centreline Angle, = measured angle between the intake and exhaust lobes on the cam.
